HiFi Racks do a narrow Podium XS which looks perfect for power supplies and would match your existing.
Hi Paul52135, I have seen that but going to go with an additional shelf which will free up the floor space and keep my wife happy but thanks for mentioning it.
Not exactly a system pic… a local band asked me to photograph their new record. I worked some subliminal Naim advertising into it.
Looks awesome Chris!
They’ll be a sudden spike in demand for Olive kit
…and the Nait 2, nice photo Chris.
As someone who normally finds Olive kit very ugly, that is by far the most aesthetically pleasing I’ve ever seen it look - well done!
Grado headphone demand might also rise…
Mark
Would also raise the LP12 up a bit, so less bending.
Need all the help we can now…
DG…
Also some Grado as well🤣
And then a wave of disappointment when they realise it doesn’t have a headphone socket
The Whisky will help ease that disappointment
the female singer too
BTW, I will listen to that band
Major back surgery, not so steady hands and iffy eye sight makes cueing up a track quiet a challenge DG…
Changes for 2022: (1) 2nd 555 ps dr for the nd 555 (2) ProAc K10’s and out with the Focal Maestro Uptopia’s. Had to buy the K10’s blind, was not a single pair in the USA. Did my research and Listened to my dealer’s recommendations, good choice.
That’s is one wonderful system, room and setup. It must be an absolute delight to enjoy. Nice one.
Sorry to hear that and hope that you make a full recovery.
DG…
No worries DG, “feeling as pert as a rutting buck”…though not sure the wife would agree but thanks for your kind words.
I did the same with my K6 Sig’s… bought them unheard, no demo. Relied on the advice of trusted sources and could not be happier. Sadly the K Series is poorly represented here in the USA and that is a shame as they are so good. I’ve heard all the competition and nothing comes close.
The ribbon tweeter will take 200 hours to open up and another year to reach its full potential. You’ll know it when you hear it. The bass drivers need to be tightened down twice a year. I asked the factory for a torque setting… they said just “nip” them down, don’t over-tighten. It makes a difference.
That’s good to know. Pretty pleased at about 60 hours already. I’m still thinking about the Gaia. Thanks
Is there a Naim single malt in the offing….
