System Pics 2023
May be time for a new avatar :frowning_face:
.sjb
Hard to get a shot but this is what I have.
As I say it was Andy in Signals who set them up for me and I have not moved them a mm since then.
You can see from my stellar performance with my fraim why I am willing to pay for an expert to set them up for me!
.sjb
Thanks. I wonder if my crossover cables are a shade too long. This is how they were when bought new in 2004. Maybe @Richard.Dane could comment
I think that goes to show with the right contrasting tones and offset colour (the plants), that all black gear and racking can in fact be elegant and soft.
Kitchen/dining/living room
Slight change from my initial post with the addition of a used Fraim base for the 552. Not the last word aesthetically, but it’s unleashed the quality of the 552 - taking it to an another level all together.
I’ll brace myself for the onslaught of suggestions :eyes:
I thought you had an olive component of some sort Mike - gone ?
Yes, there is an olive SC (DR) sitting here in a box in my room waiting for the courier to take it to a new Naim home tomorrow, along with the 252.
Enjoying the 552 I’ll bet :+1:
It’s very immersive indeed.
Odd - it may be the way they are dressed, but they do look a tiny bit longer than usual. IIRC the cables were of a standard length cut on a jig, so not sure why it should be so. Maybe it’d down to the dressing? Perhaps try to manipulate them so you get a more even and shallower curve.
Well done on the build Mark. Looks great and I bet they sound amazing. What happened to the CNO build? You might find those Illuminators are enough. :+1:t2:
Ok will check. Also the PXOs were not serviced. I will also ask about this since there is a mixture of electrolytics
The reflections were increasingly annoying as the volume went up, so I went for Plan B - turn the room around to match the ceiling and add furniture.
A few changes since last year. Now have full 500 with Kudos 707s.
Very pleased with the sound.
The back drop doesn’t look too good with the garden furniture under wraps.
A new year, a renewed system since my last System Pics post.
I think a lot changed, gone from 272/250dr to this. Last week I wanted to trade in the 250 for a 300 for my end game, but then the new classics started, so I will see what happens first and I might revise that vision.
I can see a health and safety issue here :flushed:
Really nicely taken photo’s. :+1:
Fair.
I have now got a white cat 5 Ethernet cable and a blue cat 6 cable. One or the other will go over the doorway to remove one death trap tomorrow. I hope the two sound the same so I can use the white one - we’ll see/ hear.
When I come back to Tas in November, my luggage will include 2 x 7m of Kudos KS-1 speaker cable so that they can go the same way and remove the second death trap- unless the cables get me now and make the next trip irrelevant.
I may also bring Isoacoustic Gaias.
Thank you!
