Really like the understated system and lovely room. Just curious: what is the soundbar you are using?
Nice Kronos set up there
Do not be embarrassed, thatâs a killer system up to 99% of music listening public and a lovely room to boot.
I used to run a Planar 3, Mission Cyrus 1 (similar shoebox form factor) and Gale speakers and Iâd have killed then for an RP6 and Nait 2!
As with all things in life, itâs about priorities and achieving enjoyment of your music within whatever budget you can give to it and youâve clearly chosen wisely.
Enjoy your system!
Hi Toscana itâs a Sonos Beam 2. Good enough for our condo and I really like the Sonos software which is stable and easy to use. Have a couple Sonos 1 speakers in back for small surrounds as well. Not big into home theatre, just wanted something that sounded better than the dreadful TV speakers.
Upgraded the Klimax Radikal to Klimax Radikal 2 in March.
Added the NDX2/XPSDR in June.
Found a Freshly/Serviced Recapped 252 two weeks later.
Swapped the XPSDR for Rega Aura in July.
Just added the Hugo TT a few weeks ago so it was an expensive 2022.
Hopefully my Krystal will make it though 2023 so I donât have to spend anything this year.
So youâve been secretly sneaking a new queen into the house me thinks, congrats on your S1, Sir !
I was aiming to hear some of the top tier aavik and that dealer uses the borreson speakers but their is also a good deal on a pre-owned (but apparently not used) aavik I-280. maybe I should just grab that.my naim system is identical to what you had but also lp-12 and tuner and cd. thnx. Would the 280 also work well with 606?
Well I was very impressed with your demonstration of the beer glass support system integrated with the top of the S1!
I-280 would work perfectly with Kudos 606s. I feel the Aavik 280 level is the âsweet spotâ in terms of performance vs cost. You should get a very good trade-in on your Naim equipment so cost to you should be reasonable. Donât forget you also need to purchase a power cable for the I-280, it doesnât come with one. I use the Ansuz X2 series and it works very well.
Aavik i-280 is simply a great amp.
Might need a phono connection too. Not sure talk to your dealer.
Some of the systems I really enjoy looking at are, just well constructed made from ââinterestingââ components such as Nait 2 and Falcon speakers
good socks
bless
Thatâs a great view out your window. Love NY havenât been back for about 5 years, one of the most interesting cities in the world.
New York, New YorkâŚ
âThe city so nice they named it twice.â
