My room is very tricky but speakers are 1.7m apart (centre of tweeter to centre of tweeter) and I sit c1.8m away so pretty close to equilateral triangle.
The speakers pretty much disappear and the sound sits above, behind and around the speakers. I do try and keep speakers away from side walls and as it’s a room that only I use I have complete flexibility.
Same system as last year, so not a full picture. Added what is called “the little village” that come’s alive at night and after a bottle of wine and Bowie at the Kit Kat Club it’s all sounding swell.
…but wait. I definitely prefer the Titan 808s over most others!
That are truly endgame speakers. Maybe WvL or Audionec, but thats kind of „doesnt matter“ in THAT region, huh?!
The only Naim here are the Bananas on my K400.
The sources are Linn: a fairly loaded LP12, a organiked KDS and PreAmps (monos) and Stereo PowerAmp by Lejonklou.
Cables are a mix of Linn, Lejonklou and Chord.
I have gear in mind to check out, but only when funds
allow me to !) -
Always tricky with speaker placement in my room. I do try and keep some distance from the side walls to get a more direct sound.
I had to go down the GIK panels route to help bring the sound together - some ceiling, first reflection points and bass traps.
I don’t get brilliant bass per se as the construction of the room is far from ideal (plaster board with large gaps behind it). The Rel sub does go some way to help and I have a second on order for a stereo application.
Got the Fraim last year but waited to today to raise the Vulkan wall shelf so the stack would fit under. Space is scarce in this our second home so the extra floor space was welcomed. I also moved my Advance WTX tubestreamer permantly to my second home.
Also, the cat managed to damage one of my Harbeth 30.2 Anniversary and they have not arrived yet. The silver eucalyptus was all used up so it will be walnut. Harbeth put all the old stuff in the new boxes and make sure everything is up to spec. My old Linn 109s gets some exercise during the wait.
Only plan for 2023 is to send the 135s and the 52/SC to service.
