Mine come out slowly aswell,
to replace the thread you can use a helicoil kit.
the kit comes with a drill, tap and coils.
just drill, tap and replace the thread with one of the coils.
Thanks, I have a tap and die set,
Quick tip when attempting the seal test…
Use a plastic bowl/cup on speaker cone to compress woofer - saves too much pressure in one or two areas if using fingers
An interesting idea, but if you use all five fingers, you can get even pressure. I can’t imagine anyone would be silly enough to try it with one or two.
Superb clean up job @GrumpyOLDvinylJUNKY I’m fastidious bordering on obsession and I’d be proud if they were mine.
When you are done, I bring mine over
£30 ph
Taken about 6 hours so far, 36years of dry glue is a pain in the ass,
I would pay 30 pounds per hour
But my SBLs are too far away from you I think
It’s an easy job to do, just takes a long time,
As in earlier posts, only effective way is
Isopropyl, cotton buds, and lots of cotton rags,
Good thing is playing music while doing it, being close to the speaker,
Well done, they look so much better without the horrible velcro.
Wish i had done that to mine now
Phantastic - respect for your patience!
Come back tomorrow and I will have the grills on,
And I’m not using lengths of Velcro either,
