Is the floor solid or timber? (I assume the wall is solid.) If no timber then solving is less pressing.
IB, itâs in the extension and unlike the real house, itâs a concrete floor. Behind the radiator is old drywall which is unaffected. As far as I can see, this is the only type of drywall which seems to soak up the water.
Good old rising damp, might be worth checking the exterior inc downpipes, gutters , shrubs etc as this can contribute. Probably a poor damp course on the extension though.
Right! You need to remove the ivy and inspect all the downpipes and drains - what does it drain in to? Might be just a French drain / soak-away which wouldnât help. Also maybe remove that raised planter and let as much air in as possible around the area.
Good advice there. Depending on what you find, also see if you can deflect any water away from the wall and improve the soakage - the pavers looks blocked up with debris.
This part of the garden gets stripped late 2022.
I need to keep the Ivy, but I can prune it seriously.
The stuc is removed, but I was finished too late to get some Knauf stuff to fix the wall. A task for next week. There is some time pressure since our floor gets done in 3 weeks time. Itâs an oak floor which gets renovated.
Dry out the wall and paint the affected area with an oil based sealer before repainting.
Has the happy hour started?
Happy hour! Iâve not even had breakfast yet. Anyway as you get older just knowing youâve woken up is reason enough to be happy.
Howâs those long hours at work, hope youâre taking time out to enjoy life.
Iâm surprised it sits on a timber floor
It doesnât. I got the foundation adjusted. It is placed on its own foundation. A photo before it got installed - doesnât show the bricks below it, but you get the idea:
No I didnât who won ?
Iâm watching the replay on Stan, unfortunately I made the mistake of looking at the 6 Nations thread earlier. Iâve got 20 minutes to go, France in front and they do go on to win. It shows their win against the ABs last year wasnât a fluke and theyâre in good shape for next years WC.
I would like them to win World Cup good for rugby IMO
Agree, Iâll be happy if itâs anyone other than the ABs or England.
