You can connect a CDP of course and yes, I meant the Nait 50 headphone for when (humbly, of course!) listening to TT or CD directly
The HE has a high quality volume control and to my understanding does not need to be at any particular volume level. I have tried it with a few amps at low and high volume position and no loss of SQ in that respect.
This sounds like Unity Gain which means the equipment is not changing the volume level, as if it wasnt in the signal path. I know that Unity Gain on all Linn gear is 80 but not familiar with Naim. Certainly appears that they use 69 on this device.
Itās a pity isnāt it. Such a nice little amp but apparently can have this imbalance problem. Whatās your plan? Are you going to return it to the dealer? I am yet to decide myself what to do.
It seems that Itā s a little short of breath with IBLs now, where on the other hand was pretty much at ease with S600s. Apparently IBLs are really demanding little speakers since the other pair, really shining with my 500 now with Max B, his Supernait 1 struggles a bit.
I thank Will try now with 202/HC/200
Yes, itās really a great pity. Iām not sure yet, I canāt keep it as it is, but Iām trying to find a solution with my dealer. I have no desire to gamble, so Iām not going to try out several Nait 50s, if my dealer would even go along with that. Iām also not in the mood for a repair straight after a month.
Iāll either go back to the Atom or try something completely different. Iāve always found the Lyngdorf TDAI-1120 very interesting, or maybe Iāll end up with active speakers like the new A10 from Buchardt.
With something like a Rega above P6 and e.g. a higher end Shibata or SLC stylus, especially with the Nait 50, I think you would be far less likely to think of the sound as warm and fuzzy? May be worth trying?
May be P3-P6 or a lower/mid LP12 with MM could feel fuller but a bit ātoo warmā in general? (in my experience at least)
Hi, yes it was the relative lack of definition in the upper mids and highs, yes I know there are some very high end MM cartridges available, but for similar or less money I can get a flatter, more insightful to my tastes presentation say with a modern OC9 variantā¦ I think ultimately itās a limitation of the mass and momentum of the cantilever with MM over the MC which requires serious effort and cost to compensate for.
The last time I had a turntable I had a MC, so I guess I am used to that presentation as my listening session on Saturday across multiple cartridges and turn tables showedā¦. All good funā¦ nothing is straightforward
I ran IBLās for several years with a slimline 92/Flatcap/90 and they sounded mighty fine. When I upgraded to an 82/Hi-cap/250 (olive) there was certainly an increase in authority and the bass filled out nicely. But at the same time the sound now lacked the speed and light-footedness of the smaller amp. Apparently driven active they are something else again.
I have just successfully completed the swap nSat with Nait50 and IBL with 202/HC/200, iām really really positevely surprised. It seems a totally different loudspeaker now with bigger scale, more tuneful bass, better and more trasparent midrange. On the other hand, the nSat with Nait50 Itā s still very good. So Itā s win win situation. Also i just talked with Massimo and heās really enthusiastic with his rosewood pair
The IBLās also have their roots firmly planted in the analogue era. They undeniably give of their best with an analogue source - the LP12 being the one of choice.
Yes of course they work with digital, as they did in my set-up, but as with the Kans an LP12 wrings the absolute best from them.
Regarding the imbalance issues experienced by some users may I suggest their speaker cables are checked for firm clamping of their wires within the banana plugs or other connectors at both ends.
Donāt overlook the often overlooked high output MC option. The second time I had a Planar 3 (back in 2001) I ended up using a Denon DL-110 which was the best Iād ever heard the deck sounding. The only reservation was the slightly reserved/polite sound, which Iāve heard from nearly all Denon kit - CD, cassette or minidisc. Must be their signature.
More recently I had a Rega RP6 with a Hana SL (low output MC) which was better still and since moving to the dark side, my LP12 swiftly went from an Adikt MM to a Hana SH (the high output variant) and Iām more than happy with the result.
