Roon can control volume on devices that allow it access, such as Unitis and streaming preamps. It can’t control a Nait 50.
Got it, thx
I use a Limetree Network player with Roon. If I turn the NAIT volume control up, I could vary the volume with the Limetree. I never do it that way though.
Yea, that’s the kinda thing I meant. Thanks.
How do you like the Limetree? They only had one US dealer in Oregon when I looked them up. They are Roon ready though. Fingers crossed for a Nait50 streamer someday.
Skip
I really like the Bridge II which is a streamer only. Added an external linear power supply from Sbooster to it and it was an awesome update.
I’m looking for a little streamer for my NAIT50, and I think I will go for the little CAMBRIDGE MXN10.
Does someone go for it ?
just ordered one of these. located one 1210 in the loft. other one MIA. what phono stage? last time i played vinyl was with a mixer 20 years ago…
I have an Ortofon ST-7, made in Japan, so you need to find one in that part of the world.
My set up uses a Chord Shawline cable from the SUT to the Nait50.
cool, Ortofon, you have good eyes!
I’m confused…thought you you wanted a phonostage, not a step-up transformer?
i have incoming nait 50. one or two 1210s, two speakers breathing down my neck. just that middle bit…
Remember that the NAIT 50 has a rather good MM phono stage onboard.
cool, cheers Richard. getting a bit excited…
Lots of Step Up Transformers available in UK … aprox £150 upwards. Simple google search finds them
But he would only need it if the cartridge was low ouput ( MC ) … I think the Nait 50 already has a MM Phono input
love this stuff…
The Shawline cable goes into the MM phono input on Nait 50 Graham ?
Is that how it works ? Nothing more complicated than that ?
MM phono stage, my homework.
can i plug it in? day 1. speaker cables natch
ndx2
1210 (s)
