I bought for the same price in the beginning of the year
Agh yes, but the absence of these is possibly one of the reasons why it sounds so good ā¦ there are minimal non audio specific electronics or other non key electronics robbing the performance.
I note some high end amps like DNM amps follow similar principlesā¦ use of DIN and no non audio electronics. They even have separate pots for left and right volumeā¦ā¦ perhaps a step too far for Naim.
Hello Simon, I hadnāt thought of that.
I recently had a very, very bad tear in my knee - which left me in very serious discomfort and pain - and would rather have liked a remote.
Best wishes
Sorry to hear thatā¦ I cheat ā¦ I use the remote and digital volume control on my DAVE when using that as a sourceā¦
DIN interconnects are readily available. Itās only an issue if you are buying and testing a stack of cables and then trying to sell on.
No problem at all of you just order a lavender.
Oddly enough, I started inspecting my ancient A60 in preparation for a massive service and upgradeā¦ Arcam also started with DIN it seems. Been so long Iād forgotten.
Iām sure DIN is just one small part of the magic recipe that contributes to the 50ās success.
Hi
Unfortunately the dealer does not have another one to compare mine to so it will be back to Salisbury with it. Thanks for your help with this. Best regards Neil
Recently drank the kool aide and procured some Gold Badge Falcons. I find myself in a rather enchanting position in that the Nait is probably sufficiently run in, but the cartridge is probably only three quarters run in and the speakers maybe half. And it sounds fabulous. And on paper, it should continue to sound better every time I listen to it for a fair bit. Excited to see where it ends up!
Love this simple and elegant vinyl set up, quite delightful really.
Looks good, and bet it sounds great. And if at some point you want to let the speakers shine even more, if you have the space, consider a pair of Solidsteel SS standsā¦ the imaging and lower end should get a bit of help and should tighten even more, you may well be even more enchanted
Looks great
Have you tried 3 domes of blu-Tack under the speakers?
This is my small vinyl based system. The Nait 50 slotted in perfectly between a rather high class source and speakers. I canāt stop listening to music.
Nice analogue system.
How have you connected the Urika to the 50.
Linn silvers with Mayware adapter. Plan for a Vertere Redline rca to din after the summer.
Nice one.
Tricky choice I use Silvers on everything but realise youāve only din for extras.
If your adapter is nice and tight Iād be inclined to keep the Silvers synergy with the Urika.
Save money and buy some records.
The adapter is a loose fit. So you prefer the silvers to the Chord and other rca to din alternatives?
Defo mate.
I know many with top end Naim Pre and still prefer to keep the silvers on Urika and use the adaptor.
Mayware is the audiophile choice.
Iād much rather have the adaptor than lose the synergy and signature change with a different cable.
Lovely set up.
Less is more.
Thanks for sharing your views. I may eventually reconsider the fancy cable thoughts.
If you have to keep synergy ā most recommended ā and you are determined to remove the adaptor then any of the two stock Naim cables would be my next choice rather than throwing money at something with no matching signature identity.
Your choice but looking at the simplicity of the system you have Iād keep it one way or other and not introduce an unknown variable.
Any of the below cables Iāve highlighted from Naim should fit the bill.
The Vertere Redline will not be throwing money away. Youāll hear it the second you plug it in.
