Dimension is 270 mm across the front width. Nait is aprox 200 mm.
I’ve posted a few images of this, looks good.
Somewhere safe (where did I put it?) I have a napsc/headline outer sleeve with feet attached. I’m assuming carefully filing the edge will make it “chrome bumper”. I just need to figure out how to make a front/rear panel. Then a pi with hat dac is going inside.
The Chrome Bumper look was achieved by linishing the edge of the powder coated extruded sleeve. It’s a relatively easy process using a belt sander, albeit not one for the inexperienced! You’ll probably find somewhere to you nearby where you can get it done.
Thank you for pointing this out I have 270 rather than 207 for the Nait 50 width. Unfortunately I cannot correct this now myself, if deemed important perhaps @Richard.Dane could correct.
Corrected for you. I’ve also edited your post to remove the unauthorised link and the excess of Eversolo promotional stuff.
@robert_h & @garcon Ah, many thanks, just like how I’m using my UQ2 then. Thought I’d missed something with the Atom HE and wondered if there was a line out that bypassed the pre.
Hopefully Naim will present an affordable shoebox all-in-one streamer (something like a core with a streaming unit) in the future. This would me bring into streaming and many others I think
Like the old UnitiServe…with maybe an inbuilt Dac (with Rca line out)…
Just noticed it has analogue RCA/XLR’s to connect directly to active speakers or power amp if reqd….
Yes, exactly, comparable with the ZenMini
Beauty is in the eye of the beholder I suppose. Next to a Nait 50, that looks hideous.
As does the Atom though to me.
Just hide a streamer / dac in a LP12 next to the Nait.
Appreciated, nice spec though.
Anyone with information here, when the first units will leave sailsbury?
Too bad there is nothing on its SQ yet. No review been done. I must learn to be patient ![]()
I am really interested in how it compares to an original nait 1 or 2.
End of next month I was told?
I phoned Naim two days ago (a unrelated query) and we got talking about the 50. I was told it was far better than a 1 or 2 and was certainly in Supernait 3 category. Time will tell I suppose.
For my taste, the new Cyrus Streams look good for a ‘match’…the Classic or prob the XR…due out in August I think…
