MrFixit
February 14, 2024, 3:03pm
1
Hi,
My connection to Tidal from my iPad seems to have logged out (using the Naim app). When I attempt to login I get an error: (MusicServiceKit.OAuthError error 4.)
My Google Pixel 7 is logged in via the Naim app and works fine.
Any ideas?
Edit: I logged out of the Tidal app on my iPad and could login again OK. Same with my Pixel 7. So it’s just the login from the Naim app on my iPad that fails.
iPad is running v17.3.1 of the O/S. Naim app is v6.6.0. Tidal Connect works from my iPad.
MorriAG
February 14, 2024, 3:25pm
2
Same here, Tidal via Focal & Naim app on Apple iPad & IPhone not working. I’m getting same error code as you. Stand alone Tidal app seems to be fine.
MorriAG
3
I should add using iOS 17.3.1
MrFixit
February 14, 2024, 3:28pm
4
OK, sorry, but I’m glad it’s not just me .
I suspect Naim will need to fix their app for iPadOS v17.3.1 which is very recent.
Leggit
February 14, 2024, 3:44pm
5
Same here with the latest version of the Naim app on an iPad running ios 17.3.1.
MrFixit
February 14, 2024, 3:47pm
6
So, what’s the best way to raise this with Naim?
ChrisSU
February 14, 2024, 4:01pm
7
Phone or email to Naim support.
MorriAG
February 14, 2024, 4:08pm
8
It was working yesterday.
MrFixit
February 14, 2024, 4:24pm
9
Thanks. Done. Ticket raised.
Same here. Tidal login issue.
JKal
February 14, 2024, 4:54pm
11
Same problem here. Tidal app ok, Naim app login error. Noticed this afternoon. IOS 17.3.1.
I hope Naim will fix this asap.
Richard
February 14, 2024, 5:31pm
12
Me too on a M2 MacBook Air. Tidal app and iPhone app ok.
I have the same problem. I am running iOS 15.8.1 as using Old iPad mini 4
Same here. How will we know when Naim resolve the issue
Same here from both iPad and Mac, so dont think its a iPad update issue, more likely Naim or Tidal or combination of both
Calling
@Stevesky
Osiris
February 14, 2024, 6:59pm
16
Same here @ 18.55 UK time.
Just as well I have a Zenith……
Maybe time to ONLY have a Zenith, but then it’ll probably fail too .
Isn’t networking fun…… NOT!
Interestingly my Zenith logs into Tidal just fine so apparently a Naim or Naim/Tidal issue.
ATB, J
Same here. Neither my 222 or my Muso 2 working with Tidal
MrFixit
February 14, 2024, 7:26pm
18
Try Tidal connect or a non Apple device.
Osiris
February 14, 2024, 7:51pm
19
Tidal App works on my iPad Pro, IOS 17.3.1, 19.51 UK time.
ATB, J
MrFixit
February 14, 2024, 7:59pm
20
Yes, it’s only the Naim app on iOS that is having a problem.
