saw this on the MSN home page and wondered what speakers Ms Holden has?
Gosh - mine are several days in some cases… One reckoned over a week. I must be doing something wrong. I am doing relatively thick walls, but most of the volume is empty.
My goodness what are you printing, furniture?
KEF R Series …R500 I think
yes, small furniture of sorts - a hifi rack.so it needs to be quite strong - I think the wall thickness is about 5mm thick.
Certainly looks like them
What are you actually after, strength or rigidity?
5mm is a very thick wall for 3d printed parts (in fact I’ve never hear of anyone else using anything like that).
Strength mainly - it may be a little thicker than I need, though. I’m not sure. I don’t particularly need rigidity, though it needs to be reasonably stiff. The main structures are essentially rectangular tubes, with an internal wall down the centre length. These will be filled with sand (to absorb vibrations). I don’t want them to sag, of course.
Had you thought of printing them with a channel in them (with cris-crossed grooves in the channel walls to act as a key for the expoxide), filling the channel with a thinish (low/medium viscosity) epoxide potting mixture, then pushing a steel or aluminium strip into the epoxide? When the epoxide sets off you’ll have a part that has the external shape (including end fittings as required) combined with the strength of the aluminium or steel strip.
Composites are often the best way to achieve a specific set of properties.
Yes, that is a possibility - but difficult to do in that the aluminium would have to be inside the tube, so difficult to locate correctly. I could, I suppose, put the channel/aluminium on the outside underneath the piece, but I don’t like the look of that particularly. Also, I would like to avoid metal if I can. It’s certainly a thought, though.
The current piece that is being printed should take about 30 hours, and about 280 grams of filament. It’s about 400 mm long. There will be two of those, plus a small piece which I imagine will take about 15 hours or less.
As it is at the moment, I can stand on one of these things while it is supported at each end without it seeming to suffer much. It bends a little (as you’t expect) but otherwise is OK. A few faint sounds from it (though the one I tried doesn’t have the central wall).
well, having, with your help, probably solved the nozzle problem, I now have a new one. The thing that senses the Y axis position has stopped working, and it just tries to ram the build plate up against the nozzle. AAAARGH!
@Beachcomber I suggest we move this to a new padded cell thread - I’ve opened a 3d printing thread for us and other to use and with your reply.
I made use of a very windy day to sand off my kayak project outside. Nearly ready for varnish on the deck at least. Taking time over these last stages.
I know you have all been anxiously waiting for an update!
Today I was so bored I built a chicken coop.
Truth be told it took more than a day. Still needs finishing. If anyone out there is contemplating a similar project I have two pieces of advice.
- Four sides.
- Flat roof.
Willy.
Hope they appreciate your efforts Willy, probably not from an aesthetic point of view…but if ol foxy is unable to get them😁
That’s impressive. 5 star accommodation for chickens. Wouldn’t look out of place in Disney Land too!
Did you get planning permission and are you paying council tax?
Drat, my evil “chickens in space” scheme has been exposed.
Willy.
