Turntable suggestions for new SN3
So what would you suggest as an ideal turntable to partner your new Supernait3?
Rega 6 or 8 would be nice
… though rega’s ania that is the default cart needs an mc phono stage.
A maxed-out LP12 with a VM95E.
Well loads of choice. Let’s assume a budget broadly the same as the SN3.
For starters I would suggest:
Rega RP 8 or 10 with suitable cartridge to match.
Michell Gyro/Technorm/suitable cartridge
Linn LP12 construct by Cymbiosis.
Roksan Radius/Nima and suitable cartridge.
Avid Ingenium
Vertere Dynamic Groove.
Good luck.
Lindsay
Add a SUT.
@Allante93
What is that?
Looks like Curiosity…
VPI Prime Signature, I believe.
It reminded me of the rp8
VPI Prime Signature~ 6K
You would have a hard time finding something farther from an RP8 in conception than a VPI Prime - at least without going DD.
I don’t know anything about TTs. Bought an LP 12 in 1986 $1.4K. Sold it 3 years ago $1.5K
Kind of miss it, but my theory: if you don’t use it, loose it!
Just drooling! And learning how to post pictures!
I just love listening to Music, That’s all!
I have a Verdier La Platine with a Moerch 12" Transcriptor Arm but I can’t find a pic online.
There are some gorgeous Turntables in the new Well Tempered line up. Then one could utilise the WT mm cartridge for a start.
Thanks for the suggestions. Should have said, I don’t want additional boxes with SN3 so TT need to be comparable with the new SN3 phono stage which means only MM cartridges unless I am mistaken.
The Clearaudio Concept comes with an MM cart1454354219757
Or as JosquinDesPrez rightly says you can add a step up transformer and go for MC version.
20140316_091412
Step up transformers can be very, very small like these two examples from Ortofon
ortofon-t-5-mm-to-mc-moving-coil-step-up-transformers-adapters_6785453 Ortofon-type-STM-72-step-up-transformer
There are some excellent MM cartridges available that would be an excellent match for Naim the Audio Technica AT150 EA in the picture that I own has a changeable stylus that is compatable with AT’s new VM SERIES
Which come in three different stylus types and seven grades that vary in price from £49 VMN10CB
audio-technica-vmn10cb-replacement-stylus
To £499 for the VML60SLC
audio-technica-vmn60slc-replacement-stylus
