Yes… The firmware may have adjusted the shaping of the noise profile on the streamers . and on some system configurations of some products this is causing unintended effects.
Noise can modulate most components including clocks in minute amounts, but that is a different consideration.
Your experience of the new FW update is exactly the same as mine. Although my ND, for some reason, seem to have stabilised for the moment and been sounding reasonably good. However, my earlier comments on the space between the notes due to less noise still stands.
What I think maybe happening is that some random noise is being generated by something, perhaps the code and this is what you hear as a sort of strange distortion that maybe affects perceived timing? Perhaps it’s distortion at a particular frequency, hence the edginess you hear primarily on female vocals. I hear issues in the bass as well that I think could be linked to certain harmonics? Again, I’m only guessing and trying to use my hearing experience and acknowledge that I have no clue to what’s going on in the digital world.
I was being general.. such as noise in internal powerlines, ground planes or electro magnetic fields.
When noise modulates a clock, the phase period of the clock is modulated by microscopic amounts (standard consumer audio clocks are typically less than a billionth of a second - 0.5nS) which is jitter of the clock output. Most high end hifi (and other) manufacturers go to huge effort to physically and electronically isolate the clock output to keep it as stable as possible.
Clock jitter is sample reconstruction increases the noise floor (lessens the SNR) in the reconstructed audio. Its affect however is non linear with reconstructed frequency
Thanks. Another wild guess now from my part: I live very close to a powerline, distance is less than 100 metres. Could the new firmware have made my ND5 XS 2 more sensitive to noise effects from that powerline?
I’m sorry Simon but I’m just not knowledgeable enough about the factors you mention to give you an answer (in fact I’d never even heard of these things so I appreciate you always explain what you are talking about). I’m talking about my perception of the speed of the song. To me it sounds like when you up the playback speed in YouTube just slightly off.
Both of those I have also heard - lets hope it is fixed ahead.
With this I concur that music does subjectively last longer. When I first got my Active system with the 552 Pre long ago my Dealer listened to one of his favorite classical tracks and said everythying was spaced-out and lasted longer as he percieved it.
On from then and with the S1 Pre it is more of the same and there is so much going on that an age unfolds in my mind and then you realise it has just been one track. So much information is present more than you normally hear that the sense of time is transformed and other strange stuff seems to happen.
But if measured by a machine it is the same length and all in your mind - fortunately.
This effect happens to me as well. I look for it every time I update my system now. I noticed the first time clearly when I added the nDAC to my ND5xs2. My favorite songs seem to last longer i.e Coltrane solo seems to go on forever and I hear more “notes”
Strange as this might seem, my neighborhood is just now recovering from a fierce windstorm that knocked out a powerline/transformer etc. Probably all in my mind but the net result of the replacement powerline/transformer is my system sounds even better than I remember.
