Uniti Atom firmware update issue
Just installed the update on my Atom and discovered all saved radio stations in the app now have an exclamation mark against them and I can’t select them, I have the option to remove from favourites but that’s it, not great… Anyone else got this?
I have the same exclamation mark showing, but I can still select the channels, just doesn’t show the station image
Just remove them, search for them again and all will be well. It’s a faff but the new service is much better, so it’s worth the effort.
Naim is changing the way Radio works and moving away from v-tuner to hosting the radio on their own servers. There are several good reasons for this.
See this thread:
You should remove the ones with the exclamation mark and re-add them. When you now search for a radio station you will find the one via Naim’s servers.
The v-tuner ones may still work but no idea for how long.
