Uniti Atom HE frustrations
I’ve had my Atom HE for a couple of months now.
Initially when I turned it on, the Menu was displayed as I expect which is good.
But, for the last couple of weeks, every time I turn the unit on I get a Ready to Pair message on the display and can’t get rid of it.
The remote seems to do nothing and buttons on the unit do nothing.
The only way I can get rid of this message is to use the Naim App and select something via the app.
I don’t use Bluetooth and can’t imagine any circumstances where I would.
The only thing I use is a 1TB SSD plugged into the rear USB port so the unit is always in Server mode.
How can I stop this irritating message from appearing every time I tun it on please?
Many thanks
Have you tried disabling the Bluetooth input?
And have you completely power cycled the unit?
Have you “paired” the remote as in the set up instructions?
I suspect the OP means the remote does nothing to remove the bluetooth message and not that it is not paired and does nothing at all.
Here are the pairing instructions, but your remote doesn’t work at all?
Thanks guys for your swift replies.
Yes, have tried disabling the bt input - makes no difference.
Yes, power cycled off and on
Yes, remote is paired - the remote does work, but it doesn’t help clear the Ready to Pair message on startup.
I’ve tried resetting the App too.
Is there a factory reset somewhere that I could try?
I’ve spent ages trying to stop this message, but nothing seems to clear it until I use the App to select Server or Internet Radio then I can play my music.
Try pairing it with a phone or other Bluetooth device just to get rid of the annoying request.
Failing that, a factory reset might well work. Why this is happening I have no idea. I never use Bluetooth either and have never been pestered to pair anything.
Any ideas from the dealer/naim or perhaps reach out to naim staff on here like @NeilS
I suspect it’s asking/offering to be paired to Focal Bathtub headphones, as they use Bluetooth for control purposes.
Press the Home button on the remote, go to settings and then scroll down to factory settings.
:slight_smile:
They are good headphones though.
It definitely shouldn’t be doing that - as above, try a factory reset from the menu.
Neil.
Thanks again all for your help.
First I tried pairing my mobile with it and that seemed to work.
I turned it off and on many times and all seemed good - until this morning.
I turned it on and got the Ready to Pair message again.
So I performed a Factory Reset and so far all seems good.
All the best
Pete
Pleased to say that my Atom HE seems to be fine again now.
However I have noticed that all my Favourites and all my Playlists have vanished.
I guess this is because I had to perform a Factory Reset (?)
Is there a way of preserving/backing up Favourites and Playlists if I have perform a Factory Reset again?
Pete
Yes you will lose some data when you do a factory reset. And there is no way I am aware of that you can back this up prior to a Factory Reset.
I always find it more reliable to create and manage playlists on a UPnP server rather than within the Naim app, which I have always found prone to losing them.
For Tidal and Qobuz, playlists and favourites are stored on their servers and should remain available.
Thank you both - I thought that may happen.
I don’t want to pay to subscribe to anything in order to just play my CDs, so I’ll try Windows media player as a UPnP server and see how it goes.
