Hi all! I have the following problem and hope someone knows any fixes.
Setup: I own a Naim Uniti2 and use the mconnect app on my iphone to stream Qobuz directly to the Uniti2. I also use Roon via a Bluesound Node but at times prefer using the amp’s own UPnP streamer.
The problem: I can stream 16bit Quobuz files no problem. However, as soon as I switch to 24bit or higher the playback keeps pausing (as in buffering), then continues. It seems like it is buffering / like there is a speed problem. This issue appears both with the Uniti2 connected via Wifi as well as hardwired via ethernet.
Fun fact 1: To my surprise it does not appear when I use mconnect to stream the same 24bit audio to my TV (although this might be a cast instead of UPnP).
Fun fact 2: I put a WAV file on my iphone, selecting it as source in mconnect instead of Qobuz the Uniti2 plays like a dream!
Did anyone ever experience similar issues? Fixes are very welcome! Thank you in advance!
