First I had the problem that my ripped CD’s didn’t got any metadata, fixed that after a lot of tries, no help from support by email request (maybe COVID stuff, not sure). Now the CD loads and gets the Metadata, but now the Core doesn’t rip anymore and it is impossible to abort the RIP so the CD ejects.
Anybody had the same challenge and may have a solution.!?
Check that the core still has a drive or NAS share configured as a store. Does your Core have an internal drive, or are you using an external storage medium?
In the past when my core has stopped begging able to rip it’s because the store has reverted to bring a share
Recently another user saw an issue which had some similarities to your problem and it turned out to be a faulty music store hard disc. You could test that by getting a USB stick, plugging it into the front panel, assigning it to be the music store in the core setup and then try ripping a couple of CDs. If that works then I would replace the internal hard disc and restore from your backup.
How do you know there is nothing wrong with the internal HD? The recent case I mentioned was one where the index on the HD had become partly scrambled, presumably because of a HD failure of some sort. It could still serve some music, but not all and it wouldn’t rip anymore.
Best
