USB Cable for NDX firmware
I need to update the firmware in my NDX. The instructions require a “fully wired USB A to Mini-USB B” cable. Not a charging-only cable.
How do I tell the difference when ordering?
Thanks!
Just go for one that is described as a ‘data’ cable. Most will be, as charge only cables are most commonly supplied with chargers rather than as separate cables.
I searched for that on Amazon, but none of the options came up as “data”. Suggestions?
This was covered a couple of days ago in another thread. It is the right one.
Excellent. Thank you!
