Hi - a request to Naim - I would really appreciate a web interface. Yes the app is ok, but Im often working at my laptop and want to cue up music, listen to radio etc etc. I have something called Qutecontrol for my MacBook, but its not working recently - even when I put in the IP address of my NDX2. Its probably not for the NDX2 given the name.
If you go to the App Store on your Mac or I think you can get to it from the Naim Site, but I’m not sure now it’s been ‘updated’…
This is how it looks when you run it off the App Store.
Its a M1 mabook air - and now when I restarted the app, I got all the options as shown. eg streaming. Thanks for the patience. Dont know why it didnt work first time. Appreciated - A much improved experience!
Excellent. And did you know that if you go into input settings you can turn off those you don’t use, and rename those you do? It makes everything much tidier.
I run the app on my M1 MacBook along with iPhone & ipad however the functionality is not, in my experience, 100% on the Mac, there are some subtle things that aren’t quite right I’ve found but for general use it’s fine
From a browser, connect to http://IPADDRESSofNDX2/webclient/ and you will get a very rough interface. Certainly not great, and probably unsupported, but it does work
An alternative solution, which I used for a while, was to run Bubble UPnP somewhere on the network (a NAS in my case) to render the Naim device OpenHome compatible. This means other control apps can run it and I then used Linn Kazoo on my Mac.
