This is getting really urgent Blackbird make an appointment at your health center right away so you get a prescription for hifi itching ointment before it’s too late for God’s sake!
Ah yes, Limetree, that was both recommended and advised against when I was looking for a bridge or streamer, a bit confusing. So how does it sound and how is the app?
Seems like people mix the two models up. There is one Network version including a DAC and one Bridge version with digital out and also Bridge I and Bridge II. I have Bridge II. I haven’t found a single one being disappointed with Bridge II. Then as always sky is the limit but for the money I believe it’s great but still early. I’m getting a better coax cable too and later change to a Linear power supply. This is my temporary solution getting my NDS up to date since my long term goal is ND555.
The app seems great, fast and stable. Better than Audirvāna. The so so reviews found on the app seems to be from the time before version 2.0. Will play around more with it but for now having fun with Roon again Also sent them an email where they confirmed Tidal Max is coming soon. It has Streaming unlimited 810 board in it which is from the same manufacturer as naim use in their later boxes (800 model).
Bought a used Chord Signature digital cable to go between Lindemann Bridge II and NDS. I turned the back leg on my Fraim a bit so it will hopefully work out
If you are a Roon subscriber, and a HQPlayer user, these are probably what you want, and I just bought these to test the USB input to my Klimax DSM/3, in addition to the default wired Ethernet cable input.
The SQ of the USB output of the Raspberry Pi 4 + Ropiee exceeds my expectation.
First tube for 2024. An Elrog 274b rectifier tube.
This is a little like a table lamp for the amp at night! I think I’ll need to bring out some woodwork skills to make a shade that blocks the glare from the filament for low light listening!
