What was the last bit of gear you bought in 2025?
I surely hope so, it’s reassuring to see how many that enjoy theirs.
Here the Atom HE will go into a Nagra MSA, followed by a pair of Harbeth P3ESR.
Use mine, Atom HE, with Focal Utopia’s for contemplative listening, ie not annoying Mrs O - hard to beat :+1:.
ATB, J
Perfect. All you need is a pair of XLRs. Nothing wasted. I’ve not seen an HE used with a Nagra, I’m sure it will be great.
Haha nope! Didn’t use them :grinning_face:
They work fantastically well on my floor (concrete/screed/fibreboard/12mm laminate), so much so that I’m considering going from 70s to 100s. Spikes boomed, Gaias fixed that … but what these do is way beyond solving bass issues, which they do very well, the imaging is a lot more accurate, everything sounds tighter and faster … probably due to the speakers being rock solid now.
Utopias are sweet
An Atom and Nsats with Stands :slight_smile:
I found a Gold Note PH7 phono preamp to replace the Rega fono mk5 in my P6… the fono was good but the ph7 is on another level, used with the balanced xlr on my preamp also in xlr it’s really good!
@registlse What’s the isolation under the TT?
I’ve an isoacoustics Zen, but it’s a bit chunky. Yours looks very svelte
It’s a stained oak board, nothing special.
It seems the have to be located on top of the transformer. What is the effect on the sound?
To my curiosity did you have the chance to audition the new rega pre/amp combo?
Rel is very popular in the Sonus Faber community, as far as I know. I guess there is a reason… I can’t imagine that you have made a bad choice.
Got one of the last 3 pack set from StillPoints US.
I have a tricky hight on my Antipodes K41G4, my usual Stack Audio AUVA EQ that I had previously are 3mm or so too short.
I hear great things about the Ultra SS and got a great price as it’s now discontinued new stock.
Will fit them soon.
A curtain! Should help a little with reflections.
Amazed at the improvement Superlumina gave over NACA5 I’ve splashed out on a fancy-pants CAD usb IIR to see what further improvements are possible
Thankfully there is only one other cable in the system to change if this one works out as well as the superluminal speaker cables did
I’m using Ansuz C2 Speakz on my Nait50 and will for fun try it with NACA5 and Kudos KS-1 coming month.
Which power cord do you use on the Nait 50 and which signal cable into the 50?
I had been trying out a few improvements recently, EE8 switch and various cables from my router to the switch>streamer without any great success and had started to fall out of love with system a little, the change of speaker cables seems to have turned that around and dare I suggest that the A5 was holding things back…
…I found myself unable to turn it off until late last night, so a worthwhile investment in my crazy hobby, for me at least
Currently the N50 is just using a standard cable, the dac to amp link a chord clearway, for now, at least
I’ve followed your various cable swaps with interest from afar, but not generally gone down the expensive cable route before now so this is new territory for me
Burning these 2 things at the same time. Things sounding too bright for now. Hopefully can settle down soon.
The SL DIN along with the SL speaker cables were the best and must effective upgrades I made when I had my old classics system. Give it time :+1:
I couldn’t agree more. The SL DIN was one of the biggest improvements to my system. It also works very well with the Nait50, beating the Naim Lavender and Chord Anthem II DIN (which I had before) by a long way. I’m also looking forward to hearing more impressions of the SL Speaker Cable.
Just ordered these, (I also have a rather nice pair of Focals) for travel . I find noises and people speaking difficult to adjust to , and I glaze over .
