I’ve had a Naim NDX 2 for a month or so (absolutely loving it!) and have not been able to stream Wyldwood Radio at all - at any point, I don’t think. I’ve removed it and re-added it a few times. No apparent problems with other stations. It seems to be live and kicking online, so the station seems ok.
Any ideas? Anybody else successfully streaming it on an NDX 2?
Do I see the Comissioner @davidhendon bat light in the sky.,
Wyldwood radio is a tls1.3 https station only. It was broken on vtuner yesterday due to a legacy stream url going dead, now live again. Upgrade to v4.8 code and it will work again as we have a fully compliant https stack in it that will keep things running for many a year.
Just chased this one and we are tracking moving targets. The station have moved their servers again. Yesterday it was in one place…. Today somewhere else.
Thanks Steve - really appreciate the swift response.
And yes, I’m UK based, so it’s readily available on UK internet radio sites. I understand the internet behind the scenes pretty well, but not how streaming specifically operates - will have to do some research.
Basically I’m guessing a website can lookup the streaming servers dynamically but vtuner stores a static address? Frustrating, but… I’ll do my research
Anyway, I’ll keep trying over the next few days.
Again, many thanks for the responsiveness, very much appreciated.
Mark
We’re still investigating this one. Its failing on a https certificate issue for that provider, but unsure why at the moment. It was working about 1 day ago so there is something subtle on a security check is going on.
Wyldwoods streaming provider have fixed their certificates server side, so its working again.
On a side note JB Radio 2 was also affected as they host at the same provider.
Still doesn’t seem to be working for me…
I’m just using search to find the station (i.e. not a saved favourite) but after briefly showing “Connecting…” it reverts to stopped.
Searching JB Radio2 showed two results and neither of those would play either (I’ve never tried either station before).
Do I need to flush any local cache or similar on the device itself?
Or might it take longer to propagate?
Just thought to try naim.vtuner.com directly, and in fact when I find Wyldwood or JB Radio2 and download the m3u file (I don’t know how these work) and open that in Apple Music they don’t work either.
In contrast other stations, say BBC Radio 4 or Radio 2, their m3u files open and play fine in Music.
One thought - do you have v3.7.1 installed? If on v3.7 or earlier it won’t work as this service provider was affected by a https root certificate expiring.
The urls as advertised by vtuner are good. This is all to do with https certificates failing security tests.
PS. Now I’m quite embarrassed not to have actually looked inside an m3u file – only to discover it’s simply a URL!!! Ahem… I do work in digital, honest!
Hi Gavin,
They call themselves a pagan radio station – I have no real clue exactly what that means (it’s not occult or anything like that), but the music is “Folk, World, Spiritual & Ethnic Music”.
It’s generally quite mellow but they throw in some odd metal-ish, probably Scandi?, stuff here and there. I like Scotlander radio, too, which is more obviously celtic, but they’re akin, possibly along with Radio Paradise Eclectic mix.
Obviously I’d say give it whirl – I think you’ll know quite soon if it’s your bag or not.
Enjoy!
