Back from holiday after plugging and powering on everything circuit breaker went off.
Xps not lightening.
Fuse looks blown.
No replacement one at its side
Value: 1.35 A 250 V. Do not even know wheter the correct value as bought the unit used.
Please advice
No, that appears to be the incorrect rating - it will say the correct fuse rating on the rear of the unit near the fuse holder itself.
I would purchase a few of them from a Naim dealer as they will stock the correct ones. FWIW - i purchase mine online from dealers such as Tom Tom Audio.
See here for more information - Equipment Fuses
Hi thanks, so why was there an incorrect value fuse?
Iāve found the exact replacement inside an hicap dr ( there were two of them) and seems to work ok now
The HiCap one is an incorrect rating for a XPS2 and for safety reasons should not be used as itās of a higher value
Ok Iāll definitely get a Couple fro a naim authorized agent.
I had this happen once. After changing the fuse it didnāt re-occur for the next year or so of ownership before I replaced it with a CD555PS. Itās an occupational hazard with the XPS2 inrush current. Donāt worry about it. You are good.
I have never actually āboughtā any fuses for my Naim units. My dealers have always been most helpful & generous.
Same here.
Be absolutely sure to replace with exactly the correct value of fuse(s).
The one inside the XPS2, as specified by Naim is: 20mm 2.5A 250V Slow Blow / Antisurge fuses ā Naim use fuses made by āLittelfuseā from their 213 series."
Available from your Naim dealer or from RS Components.
I bought a decent number from RS Components as the XPS2 does have a tendency to blow fuses rather too often. Thatās why I bought a box of them !
Littelfuse. You have to spell it right if you are searching for itā¦
Autocorrect ācorrectedā it. Iāll try and amend my post!
I found someone suggest Littelfuse 213 series and other 218. Which is the correct one?
For an XPS2 you want the Littelfuse 5 x 20 2.5A T Glass Cartridge Fuse, Part No. 021302.5MXP
Same with my dealer. Maybe it is the same one ?
Choice of two - past & present, both LE postcodes⦠![]()
CH code actually
Definitely not, then.
CH = Chester�
LE = Leicester, definitely.
Yes CH is Chester
