I read the notes and see that the DVD comprises extracts from the Led Zeppelin DVD, which I can recommend. I suspect that can be bought quite cheaply too on eBay.
…… and I, II, III, HotH, TSRtS, PG, IttOD, Presence
Heck, even Coda has a couple of crackers on it.
(Have I missed any?)
BBC Sessions has some great tracks on it…
The masters of the 1990 box set/2-CD compilation are completely different (George Marino) and sound far, far superior to Mothership. That’d be the one I would go for:
I have the 4 CD Led Zeppelin set, plus the the 2 CD Box Set 2 - which gives me all the track, but in a totally different order…? Page described this as the same picture, in a different frame.
I cannot comment on the Mothership CD.
Zeppelin were the first group I ever saw live. It was at Aberystwyth King’s Hall, January 16, 1973. I was 16! Seen Plant 4 times - once with Alison Krauss.
That’s a great tip, I shall try to remember it.
Ep.7 is out.
If you want to watch it, head to YouTube - same channel.
No more updates from me…
Hi, I need some help!
I have LZ first 3 albums in 24/96000 only. Cannot remember where I purchased from but they are excellent imo.
However, I would like them in CD format. Can the Zeppers out there recommend particular releases I should go for?
Also, anything I should avoid?
Many thanks in advance
Led Zeppelin SHM CD Japanese boxset.
Often voted on this forum as being the best sounding Zep CDs, and I think they are available individually.
Be careful though, if you decide to go for the boxset, as there are many rip off copies out there, and I don’t think it’s available from the original source, CD Japan.
Good luck.
Calm down @IanRobertM I have these but most are 24/96000 downloads. So I would like good quality CD versions.
Really appreciate the recommendations
