Perhaps Mr Spoon doesn’t want to stir things up with Dcs…
The dbpoweramp people are great, really helpful. Hopefully it won’t take too long. When I found a problem with the latest Asset release they had a beta fix in a couple of days, though this may well be more challenging.
Nothing to be scared of, download & install update, job done.
Nothing gets changed, config remains untouched, everything works just as before.
In the background there is a tonne of software/background stuff; go to the dBp forum Beta Test section if you want to read about it, it’s all on R6.4 beta.
Whatever, nothing to be ‘scared’ about.
@Mike-B I updated to Asset 6.4 successfully,thanks for your help. I noticed that Album Artist/Album and Album by Artist are now under Additional so you have to navigate to Additional first then to Album Artist/Album or Album by Artist. Is there a way to get them on the main screen? I know that @anon4489532 uses QNAP as well and might know.
I have these two under additional as I never really use them. If you want them on the front t screen it’s just a matter of playing with the browse tree.
