My strategy - not that I’d ever call it that - is simple - make it & keep it tidy.
I make my own IC & power cables so these are made to fit & that removes all the loops & other rats nest tendencies.
I also have a shorted NDX-XPS burndy
I designed & made the rack to incorporate a place for the power distribution block & a hiding place for one channel speaker cables - folded not rolled.
Cables live in plastic conduit
You might note I don’t follow the loose loops & not touching anything malarkey
Peder, you are being unfair pulling out pictures from the forum with no context from the original posting. This a great system, all systems need an overhaul from time to time, you need a strip down. The owner of the system has a good sense of humour…but you pushing your luck.
Ooo me sir !!! , weren’t me, 'onest.
The only XPS fuses I have blown was when I had one at home on demo.
I should have added a sneaky little ‘T’ to the T-XPS.
But, yes maybe a speel cheker mite be yousfull
Its not my system…just a picture somebody has pulled out from the past on the forum…someone i know. Its a great system. The wires are irrelevant…if it sounds wonderful for the owner, so be it.
I’m looking again at your solution, Mike. What do you mean by “folded not rolled”? Is it bad practice to loop long cords and hold them together with twist ties?
Bhoyo,…Short answer,.yes,it’s a bad idea to roll up wires.
Put them back and forth instead.
And,…never “pull together” cables too hard…then you kill the music in your music-system.
Let them “hang as freely as possible”.
If you have to “pull together” some,.do it very,very loosely.
Yes indeed, to “shorten” a length of speaker cable it should be folded not rolled. Rolling a cable adds inductance & although one or two turns won’t be significant, each circle (turn) adds to the sum & will cause the top end to roll off.
Folding, each half turn to the right followed by half a turn to the left cancels the inductance.
Folding with ty-wraps is good, this pic is Naim NACA5, I do the same with Cord Odyssey
