Looking analytically, I now realise that although the Morgana was a big incremental step. What it has actually done is unmasked the full potential of what was the biggest leap in my system. Replacing the ND5-XS DAC with the Qutest. It shows just how good the Qutest is.
The Allo Shanti was an obvious improvement from stock and the Plixir blew the Allo Shanti out of the water. Allo is so inexpensive that itās basically mandatory for any Qutest owner. However, I did find that certain USB battery banks would eclipse the Shanti in certain areas of performance. Whereas the Plixir is superior in every area one could categorize sound reproduction, even compared to battery banks.
AudioBaconās Jay did a recent LPS shootout and the Plixir did very well.
I was actually shopping for used Paul Hynes SR4-Tās and SR7ās (or a Sean Jacobs, which are $$$ and impossible to find used). I have a local buddy with both an SR4-T and an SR7⦠both in 5V. He refused to part with either but I did get to demo each against the Plixir. The Elite BDC was roundly better than the SR4-T on Qutest and it traded blows with the SR7. Edging it out, for my tastes. The SR7 is basically legendary so this is huge praise for the Plixir.
James at Plixir (founder and engineer) was great to work with on getting items sold and shipped directly to me.
I ended up with a Plixir Elite BDC power my Lumin D2 (upgraded from SBooster) and on my Roon Nucleus +. All have been superb.
I have a couple of Seanās mains cables. Very good and sensible money. I just added one to my Whest phono stage. The uplift was both obvious and significant. Heās also a very helpful and knowledgeable chap to deal with.
Sean is fantastic from all appearances. His work certainly speaks for itself. I believe he and John Swenson design power supplies for many companies, including Innuos. In addition to their own in-house efforts.
Question on the WH Morgana. I have it between the NDX2 and SN3 but the fitting is quite loose. Anyone else experienced this? Music sounds good, am just concerned the connection is sub-optimal.
Initially my reaction was the same as yours. Iād not describe mine as loose but they clearly donāt lock in place. Elsewhere in this forum I believe there are those of the view that NOT locking things in place is better. I canāt comment on that but would note that Iāve never had a WH cable drop out or somehow sound patchy or intermittent.
I have just ordered a Morgana din to XLR for 272 to 250 so am waiting to hear what all the fuss is about. Will report once it arrives.
Not sure what their delivery times are like currently.
Morgana arrived two days ago and I have to say after a few hours it has made a noticeable improvement in all areas. Really great vfm upgrade IMHO.
I am presuming it will continue to improve slightly going forward.
Great quality product and delivered in less than 3 weeks.
Thatās consistent with my experience. Iāve found that WHs cables give an immediate and noticeable improvement and then either as the cable runs in or your ears become acclimatised, you hear more tone and detail over time until it becomes the norm. The key thing though is you donāt have to wait to hear what they do.
Iāve always taken comfort from their returns policy but having done back to back tests to check what has changed, Iāve known within the first few hours that Iām keeping them. I wonder how many returns they actually get.
I tried Morganas - I liked them enough to keep the set. Then I swapped 250 for 300DR, a good upgrade but it meant using the original XLRs again. The WH sale has delivered Morgana Mono XLRs, and it has done exactly as expected (they will be staying too). They rank well above signal-only cables for size of SQ upgrade.
I am delighted to report one more result. To my ears only and in my systemā¦
I spent an hour on cable-dressing with all these Morganas, trying to be good and trying deliberately to be less good. The really good news is that with standard cables I had to admit that the effort was needed, but with Morganas I simply canāt hear any difference rom extra care. I didnāt deliberately wind mains cable around signal cables or make lots of tight turns or whatever, but I heard enough to make me feel less guilty about my usually imperfect attempts at cable-dressing. Hurrah!
I am almost tempted to try Morgana between my Stageline N and SN1. Spending more on the interconnect than the device it is connecting does seem crazy though. Mind you my dealer recommended a dedicated HC-DR for the Stageline, I did reject that suggestionā¦
