Cheap way to enable Roon streamig to older NAIM streamers
Been looking for a cheap and easy solution to be able to enable older Naim streamers to be Roon enabled…
One cheap and cheerful way is to use a Raspberry Pi – one you build it yourself or get a ready made one from a well know auction site for anywhere between £110 to £125. (building it yourself saves you around £20 - £10 if you decide to use the 8GB raspberry Pi and nice metal case) – this installed with the Roon endpoint software
However the problem with this solution is that the older Naim streamers do not support a USB input.. (at the rear – not sure if it’s possible to use the front USP port as a input from a Roon endpoint device)
An alternative is to again use a Raspberry Pi (I used the 8GB version £73.50) + HiFiBerry Digi+ Pro (£38) + case (£12 for plastic or £22 for metal) + Power supply (£7.50) + microSD memory card (32gb approx. £6 from amazon) – all in for less than £140.
You do need to be able to put together Raspberry ‘parts’ together – it is actually easy the hardest part being installing the spacers and screws to keep the built unit from coming loose – no soldering at all is required.
This YouTube video give the necessary instructions on loading the software, etc. and the links to the necessary software.
The advantage of this solution vs a installing a Roon end point on a Raspberry pi, is that the HiFiBerry Digi+ Pro solution give both optical and digital output (at up to 192MHz, 24bit) which can be fed into any of the older Naim streamers.
I was able to use the Roon app on my table to stream to the Raspberry Pi connected to a NDX – and also stream Qobuz via the Roon app to the NDX
There is some software that you will need to download from the web (all free) – first to burn the PiCorePlayer software and a second app – app to identify the ip address of the Raspberry Pi to set the output to the digital outputs (vs the default analogue output) – I downloaded an app on my android phone for this. Both of these software was free.
Once I got all the neceaasry parts together, it took me about 1 hour from start to connecting the device to my NDX and playing music…
Soundwise - it very good. I understand that further improvements can be made by upgradig to a linear power supply for the Raspebrry Pi (need one that outputs 5V at 3A via a USB-C ) - looking around these cost more than the Raspberry bundles itself… I havent tried this upgrade myself yet.
Because the Naim streamers buffer the digitial input, I wonder how much improvement will be gained for the additional cost…
Happt to provide more details if anyone is interested…
I use a Sonore UPnP Bridge, a bit more costly than the Pi but provides a UPnP feed to my ND5XS. The ND5 just sees the incoming stream from Roon just as it would from the Naim App.
No you can’t. As you say, pi plus digi hat is the simplest way, I run mine on raspbian os with roon bridge installed. Once set up you never need to fiddle with it. Must have had mine for a couple of years or more.
An alternative software is RoPieee. Work’s flawlessly.
Do you need an 8GB RAM RPi? I am running several RPi’s for Roon streaming and 2GB seems more than adequate and, of course, a lot cheaper.
Dave
A RPi in a fancy case! :grinning:
Dave
I’ve also had good results using HiFiBerryOS.
Dave
With the advantage that I don’t have to use shonky USB or RCA connections. It just plugs into the LAN.
Don’t forget the possibility to just add a ChromeCast Audio dongle. Hard to find a cheaper and simpler way to add Roon capability.
The limitation with the Chromecast Audio dongle is that it limited to 48KHz (or is it 96KHz - cant remember) - the Raspberry Pi solutions limit it 192KHz
To the OP, is picoreplayer a roon end point or are you using airplay or something?
Never used it so dont know.
I have three raspberry pis here running roopieee which is a genuine roon end point so no need for airplay etc.
It emulates a Logitech Media client - which is supported by Roon
Jazzman22
I got the 8GB version for two reason - firstly the price delta between a 2GB and 8GB was not too steep and secondly, if I find a neater solution, I could use the Pi for a different project.
Fair enough. I run Daphile on my streamers for the same reason.
I think you will find Roopiee is better placed for roon though on a PI. To use LMS in roon, you have to turn off its main server functions. Roopiee XL allows you to airplay which is very handy. and by that I mean airplay anything to the endpoint. My son for instance airplays his youtube music to it whilst washing up, and I use it for roon when cooking dinner.
It’s your call but 2GB RPi 4 circa. GB£34.00 v. 8GB GB£73.50.
Dave
The thread title was “Cheap way to enable Roon streaming…”. Depend’s how cheap you want to go I guess and still achieve acceptable results. :grinning:
Dave
I thought £165 for a flawless out of the box solution was terrific value. Nothing is connected to the ND5 other than the normal network cable and the DC1 cable to the nDAC.
Currently $229 + shipping + VAT from the US. Not sure there is a UK supplier.
Dave
I have a couple of RPi with Hifiberry hats that I used to input into Unitiqutes. I was happy with them as a lockdown project; but then I cracked LMS2UPNP, an elegant software solution that identifies all my Naim units. I have yet to find another yes for the RPi, although I have plans to Roonify an old Quad system.
The LMS2UPNP software runs on my MacMini; it needs some under the bonnet tinkering, but I don’t mind that. And it’s free.
There’s a thread that walks you thru’ the process: HowTo: Roonify non-Roon streamers (lms-to-uPnP)
I got mine from the US. Arrived in a few days or so. Working within minutes :+1:
