I’ve watched highlights of SA v India and a bit of yesterday live. Some excellent pace bowling on a lively wicket; remember those? India’s batsmen looked a bit clueless against Rabada and Co. Lack of application and technique when they are not on the flat tracks of home I thought.
If SA hadn’t dropped so many catches it would have been even more of a thrashing.
Bruce
If you can see highlights of yesterday look at the beauty that bowled Rohit. Perfect!
Agreed - cricket should be a nip & tuck game, not a bludgeoning contest with the bat. Was watching some BBL a while back, with the usual highly-spread field on a big ground, which rendered the chances of getting caught so much slimmer. Runs galore, but cricket in name only?
The Test grounds are rarely full. What I could see of the 1st Aus V Pak Test looked very sparse after the first day or so, and that was with Australia winning
I record the BBL and the match I watched yesterday was really good , plenty of decent bowling, watching Jamie Overton fall all over the place , it was entertaining with neither side getting above 160 and everything in doubt until the final ball
Crowd of 20,000 at the SCG
Watching some of these slog fests is really boring
Not much mentioned here but Aussies gone 2/0 in their 3 test series against Pakistan. Captain Pat took 10 wickets in the Boxing Day Test that’s been spoilt apparently by poor umpire (video) decisions.
Matches like this do slip under the radar over here in the UK, primarily due to Sky’s concurrent coverage of the BBL and the SA v India series. As to the poor umpiring, the solution is…? I think Pat C nailed it in his comments.
True it’s almost slipped under the radar here as well. Re thr umpiring nobody ever complains when it goes there way. The decision they’re whining about was clearly out.
I’m tempted to suggest the TMO must have been the same one who was involved in the Quins v Gloucester rugby game here yesterday evening. Forward passes galore, wholly evident from TV display angles (and I mean ‘wholly evident’), yet the TMO said ‘we cannot find a definitive angle’.
Of course, some of us are old enough to remember some of the tours of yesteryear to Pakistan, where the officiating was questioned on more than a few occasions (before independent umpires were introduced).
The stories are legion about some of the ‘decisions’ made back then, and English umpires weren’t perfect. I remember David Constant giving an English batsmen out in a home Test series, when the ball bounced way outside leg stump – the look of incredulity spoke volumes.
And this is worth a read, as it highlights the simmering tensions which often existed in those days:
