Now that Qobuz Connect is up and running, I’d like to disable Google Cast on my 4 naim streamers. Currently each device appears twice in the device list on the Qobuz app; once for Qobuz Connect and once for Google Cast.
If I go to my google account via the website I don’t see the devices anywhere to unlink them from my account.
If I go to the Devices section on the Google Home app (android), I see all 4 devices in the ‘Local devices’ section, but I don’t see a way to remove them. When I search for how to do this, I get results saying how to remove it (press and hold tile, or go to settings and remove), but these options don’t appear for me.
If I go to Google Cast in the ‘Settings and Accounts’ section of the naim app, it just says ‘Cast is enabled’, but no way to disable it.
Any ideas?
Not a big issue, and I can live with duplicates in the list on Qobuz, but I’m getting frustrated that I can’t figure out how to unlink my naim devices from my google account!
The Naim streamers all have google tokens assigned to them when they are built; think of it like a MAC address, it’s unique to each device. You can’t remove it.
Just ignore it; a phone will always see it, the same as it will see another WiFi ssid or Bluetooth device “in the air”, and airplay devices appear etc.
Even that doesn’t work. I only know this because I did a factory reset on my NDX2 last week because I changed my wifi setup, and chromecast is still enabled even though I haven’t explicitly enabled it again.
You do have to enable it in the first place by linking it to your google account though. You’d think there would be a way to unlink it from the google side, even if it isn’t via the naim streamer.
Oops…Sorry. I thought it was under input settings before. It is now under services & accounts and does n’t have an off switch. Only a usage data switch (that I can’t turn off…).
No, see my reply above. I think it was moved. I clearly remember that is was under input settings and could be turned off. But now it is under services & accounts and can’t be turned off. Sorry for the confusion.
There are power user ways to resolve this annoyance
Work out the local IP address of your streamer. Then in a web browser paste this in:
http://192.168.0.2/api/setData?path=settings%3A%2Fgooglecast%2FtosAccepted&role=value&value=%7B%22type%22%3A%22bool_%22%2C%22bool_%22%3Afalse%7D
Change the IP address - in my example it’s 192.168.0.2
It will reply with something like:
{“value”:{“bool_”:false,“type”:“bool_”},“timestamp”:1747471689229}
Restart the product (power cycle) and Chromecast is no more.
To re-enable it go through the app setup wizard to enable it.
