@Bigboy how is the sound?
is there any difference with the “NDS” one?
how did you connected the Sonore UpnPBridge? via USB?
I still have to understand it :-/
Difficult to compare as I couldn’t use Roon/Qobuz before using the bridge but so so far it sounds good and seems very stable. The NDS is not connected to the bridge so no change to the NDS set-up, just connected the bridge to the BT router with a short ethernet cable.
that’s interesting. thnx
Yes you can also use Lumin but not Naim unfortunately
Good to hear that you have that up and running,
Was the SGC dedicated SonoreUPnP Bridge unit you got?
Are you using it with Roon?
Can I ask for a quick point of clarification on the SGC dedicated SonoreUPnP Bridge unit? If it’s connected to the network, would that allow ALL (three in my case) Naim streamers on that network to become endpoints?
Only have one Naim Network player, but the SonoreUPnP Bridge searches the network
for available renderer.I would imagine a stream from the Roon Core can be directed to an identified renderer. Whether it can support multiple renderera on the same stream or multiple streams, I can’t comment.
Interesting question. I’ll try with a SuperUniti a bit later and see if that works.
Hi SP, yes I got it from the SGC, took about 1 week to arrive (without UK plug). I use it with the Roon Ipad app which has a tab for Qobuz.
Cool - glad you got sorted
BTW I have had dealings with a ‘Bigboy Makoloma’ who works for Airtel Malawi. This is his real name, and not a handle!
Not yet, need to connect the SU, should be done by tomorrow.
any news? @ bigboy
So if I got the SGC dedicated SonoreUPnP Bridge unit like the ones @Bigboy has, would this be able to direct Qobuz files to my 272?
If so, with what app?
From Roon
Ah - ok, so that’s just a way to feed Roon to the 272.
At the moment I’m still looking for a way to do it without Roon.
I think I’ll try plugging my laptop into my PlusNet router tonight and testing whether the Bubble server I installed on the laptop works better when the latop is wired.
Linn App or Audinirvana, with BubbleUpnpServer installed on your server
Cannot find my spare set of speaker cables, must be well hidden.
