Another Phonak using here (Audéo rechargeable); other manufacturers are available. I have had them for a year and wouldn’t be without them; they have transformed my life for the better.
I suffer from aged-related hearing loss mainly in the higher frequencies - the damage done, I suspect, by excessive volume in the London blues clubs I visited in the late 60s and 70s; it was worth, though.
As some have mentioned it is all in the set-up. I was very circumspect that hearing aids could make a positive difference to my enjoyment of high quality music, especially as I suffer also from tinnitus. I have absolutely, comprehensively been proved wrong; my Phonaks have been a revelation.
They are so comfortable, I don’t actually realise that I am wearing them. After five years living with the curse of tinnitus, it has been reduced to almost zero. The aids connect seamlessly to my iPhone, everything coming through to my hearing aids. They automatically adjust and compensate for different environments, machine learning as you wear them.
Mention was made of the wax filters; with the Phonaks these are easy and simple to replace using a one-time cartridge system (caveat: obviously individual eyesight and dexterity dependent).
These aids have transformed my quality of life immeasurably, especially mutual engagement of those around me; I am most impressed with the vast improvement in my music listening pleasure.
Downside? I would like the rechargeable batteries to last longer. For the most part, I wear my aids from 0700 to 2230, and they just about last this length of time. The rechargeable Phonaks cannot be charged in the cordless charging case, they have to be charged via a USB wired case, but the aids do charge speedily.
Do your homework as best you can before purchase. Go to a reputable audiologist (I went to Specsavers) and discuss your needs; if necessary, get the set-up tweaked after living with your aids (Phonaks also can be user adjusted via their app).
Good luck.
