Triple D … that means something
sounds like we are going to need biscuits mate!haha
can only be good!hahaha
I‘ll take a beer
Says you
More seriously - glad to see you are homing in on your own ultimate system, Dan!
Teaser
500 dr in the rack - 555ps also, but not yet connected. …
sl din-xlr still in the box… all later.
Ok… here we go …
From the big bunch of upgrades I have installed:
- SL din 5-5
- 500dr
- powerigel plus only preliminary as it now only feeds 500dr. My back is so much aching - would have been impossible to strip all down
Waiting to be used:
- powerigel plus feeding all gear.
- sl din-xlr
- second 555ps.
Tested 500dr in my preliminary setup before setting up the rack.
First impressions was bass - so much better.
Done back switching to 135 only once.
135
- warmer in presentation (in a good way)
- groovy
- full bass but not very defined.
500dr. Actually going through its warm up rollercoaster
very defined bass with good wheight.
very punchy with lots of prat
lots of more detail
very controlled
much forward sounding
currently even more rough and dirty than 135 (in a good way as I liked this olive style)
today it is a bit harsh and slightly shouty (11h running) But have done some cable re arrangement (also with nd555) as he came up a bit.
Hope after a few days all is better. Will be!
Overall the sound can be described as - live concert feeling!
Edit: and again the it happened - 500ps on bottom shelf slipped of the back fraim ball - while I plugged in the burndys . Hated it and gave me another 30 min to get it back on the ball…
The 500dr perfectly adds to the sound of the 552 dr.
Nothing smooth as I Feld with 300dr - but haven’t given the 300dr the chance it deserved.
I found mine sounded really rough at times on days 2 and 3. After a week was consistently good.
Looks great my friend!
Definately warming up. Yesterday I pulled the 606 a bit back to the wall as I missed a bit bass. Today I am a minute away of pulling the back to the position
Just realized that I could not go back to lavender … not long enough
Too bad - or not. SL is fine - also in length and the very best cable when it comes to cable dressing!
So far all good - except being a bit in warm up.
The jump from 52 to 552 was bigger - but still a big step up.
Should I be worried with the 500ps slipped from the Fraim ball and glass flipped on wood.
Happened also with 555ps one year ago - all fine.
Think they are robust build an on rubber feet they dampen a bit.
And if something is broke I would have noticed.
No worries
The 500DR in my experience takes a while to come on song from cold. Give it a week or two to bed in. Also, if you are experimenting with cables it will take longer. Everything needs to be settled. My 552DR seems pretty consistent now. I also found t2 after service eas consistent after a few days.
How long did yours take to burn in?
It has not yet burned in … after 2 weeks more, after 4 weeks … even more…
When the 2 guys here doing updates at warp speed - you can’t really tell. 552 takes long, but mine were instantly very much better than 52 - details and timing. 500dr is punch and detail
Is your 552DR new though?
