1st screen shot has allegedly been identified as a specific issue with albums that have long words in there.
2nd screen shot issue has yet to be identified but, as you can hopefully see, the Last Played Tracks widget is producing covers up to 3x the size of everything else.
Yes, Iām quite relaxed about it. Love that they have a clearly defined mechanism within the app for reporting such things and such good communication once you have.
āHot fixā not for me, ticket into Innuos to resolve issue with UPnP settings, I should know better to update something thatās working perfectly well.
I decided a while back to leave it a week or so before updating due to problems like youāre experiencing. At least then crew at Innuos are very responsive. Good luck!
Peter
Not sure have to send info to Innuos, basically UPnP seems to be not working, I can operate Zenith as endpoint/stand alone but doesnāt want to play ball with other networked streamers.
Hi, finally got it working, powered down the HE and then reconnected to network, seems to have done the trick, weird thing last night this didnāt work.
Also this morning some reports on FB Innuos group regarding problems updating IOS sense app, I havenāt done it yet so will wait.
Thanks. Iāll give it a go, then. The iOS app is working fine hereā¦
UPDATE: Actually itās working fine on the iPhone but not on the M2 MacBook Air, where I just get the wheel of death. Will try M1 MBA laterā¦ Itās working fine from Safari, however.
Yet another update! If you restart the Mac, Sense seems to work fine the first time you run it, but you must then keep it open. If you close Sense and then try to run it again you will get the circle of deathā¦ Iāll just use Safari for now.
I have not been completely satisfied with how Innuos Sense has worked lately. Today I have the problem that when I play Max Richter - SLEEP: Tranquility Base from my library, the music stops several times and starts again and the same happens when I play from Qubuz. This happens when I select Linn in settings but if I select Naim Uniti there are no problems. But Naim Uniti gives me problems playing Ryuichi Sakamoto - 12, but if I choose Linn there is no problem.
When I use my Mac to play from , it seems like it hangs short in the connection.
There have been a number of interface issues. Frustrating but very much 1st world problems. Interestingly for me Iāve had a few problems similar to your descriptions. When Iāve done remote calls with Innuos the issue has always been Qobuz itself rather than Sense.
