Internet Radio FLAC
I have a Uniti Atom and 3 MuSo QB Second Generation. How do I find Internet Radio in FLAC?
It’s listed in the iRadio unput under the HiDef section.
Thank you. It sounds fantastic!
Hi, Can I get the ā€˜Hi-Def’ facility on my SuperUniti? I’ve had a look and there’s nothing like HD FLAC :thinking:
No, unfortunately the 1st gen streamers are unable to support the format used by lossless iRadio stations so the HiDef section only appears in the app if you have a 2nd gen model
…….unless you fancy getting your hands dirty…….
If you don’t want to make your hands dirty by installing it yourself, just program your favorite stations in vTuner.
Europe: http://158.101.168.33:9001/fwp/stations
US: http://129.146.133.23:9001/fwp/stations
Kurt
Many thanks guys, We’ll impressed by your knowledge. I don’t want to get shut of my beloved SU so I may have a dabble in the techie stuff.:+1:
Mind you, Radio Paradise and, 60 North still sound pretty good anyway if I can’t get a FLAC feed going…
All the best…
Hi Kurt, I haven’t followed every detail of your iRadio thread as I use 2nd gen Naim streamers - are you saying that you can ann lossless FLAC stations to vTuner and play them on a 1st gen streamer?
Exactly.
Basiscally, it’s the original OggFlac converted to WAV, but with same bit depth and sampling frequency as the OggFlac
