I can only manage 1,8 m so far.
Do you measure the distance from tweeter to tweeter or the inner sides of the speakers.
Inner sides of speakers as shown on Kudos website.
Yeah - that’s what I read in the kudos recommendation.
My stereo Triangel is a bit smaller - fine
You stayed with NACA5 or? Superlumina on its way?
Hi
No - stayed on naca 5.
Have still a wonderful offer for SL but hesitating due to my mind to let settle in.
Soundpicture is different to SBL - and my ears adapt… with better and phantastic days and …
SL is over 75% discount.
My latest mind f… is voices…
This was one of the big „strengths“ of SBL. With SBL doing much less bass all was upper mid dominated - pushing the voices forward. Same (or even more) in my second system (nd5xs2/nDAC/XPs/nait50/n-sats).
With 606 all is much more refined - and (very good) a bit darker in the mids. As now there is room backwards for the first time also the singer is placed different in some songs - in others „lap singing“ as I know it But when I concentrate on the voice, I realize that with 606 it overall so much more complete.
All is wonderful and on the other hand - there is nothing 100% pefect in life.
Ps: as a person who thinks about the influence of changing the center speaker for another with nearly same size drivers, things are different when it comes to hearing strange things
At this moment 606 are phantastic!
What they bring as impressive in a massive way is the groove!
Call it musical or PRAT … and this was more dominant with naca 5 than ks-1.
as i remember having heared all cables the SL and Vertere are more on the detail side and the naca 5 and ks1 differ in the ks1 being a bit in the detail direction. Naca 5 most complete or together sounding.
I’m not surprised you like NACA5 more knowing you like bass and low end groove They do bit of the same as Lavender do IMO. Cables is a great way to tune the last missing pieces in sound signature.
As you might know - love lavender too.
But journey never ends - maybe next stop nap500… and than …
Not that I like bass especially - I had very less in the past due to SBL in sub optimal position
Mine are 1.9m tweeter to tweeter so less if you measure from inside to inside. As you can see from the picture, im a little constrained as the room is only 3.8m wide and I need to keep the speakers away from the side walls. You can also see the slight toe-in, because of those windows which really effect the sound (they smear it if the speakers point toward)
My room is 7,5m broad - luck here.
Tweeter to tweeter I have a bit more than 2 m
A supercap as cupholder - cool
This is the positioning I’ve managed to achieve with my 606s (diagram is from the Kudos website).
I’ve settled on 30cm from rear wall and no toe-in.
I have seen this diagram. At my place a little smaller 1,8 m between and 2,05 m to front of sofa
It’s on demo. To be honest, I don’t think it’s doing much for me. The Chord M6 power block is doing much more (also on lone).
Are you a Supercap ? Hahaha
If he is, he needs to move a bit to the left
I wonder if he is a doctor, or not. I don’t see a dr stick.
NICE Finish - Walnut I assume.
Yes
I am a Bit experimenting with the position.
Currently 23cm from the wall. Measured from backside of wooden side panel to wall.
Going further back will increase bass (which I like) but reduce midrange sparkle and air? Correct.
Will test a bit more - but re arranging spikes is a real pita
