So 23cm from skirting board to base
This is how I measure with the sbl … 23 cm is really good. Carpet is really good - I am so much on the analytical / tile floor side - since 20 years. Bought a wool carpet some years ago - was a good ! upgrade
Should be just about perfect then
Can’t wait to hear how you get on with them
Black cables are powerlines. Inside the white cable shroud is Kudos KS-1.
…“can’t wait…” …
You know… there will be some Hifi Dilemmas on the way … always are
From my memory … it was you who brought up this term “nice to read about my hifi dilemmas”. This was very nice
What speaker cable will you be using?
NACA 5 cable
Get some KS-1
Googled it already … What is the difference?
It is OK price wise… Need 6 m (or 5) … if 606 is a keeper. Next round is on
As I understand it the Kudos is wired with KS-1 so it was a no brainer for me.
I was using the Witch Hat equivalent of NACA5 originally. It’s supposed to be very close.
The KS-1 was a significant improvement, particularly in the treble which I thought was a lot sweeter.
Can recommend Cymbiosis for the cables. They did a great job on mine and even spoke to Kudos to ensure everything was optimised.
As Drago is from Germany … I can only be jealous about the fine dealers you have there - like Peter from cymbiosis.
Had a quick view in the KS-1 thread… YES! That will be a good deal to go for.
Hope that NACA5 will not be a weak link so that it brings me away from 606 … (hot treble…). No dealer near who can lend me such cable fort testing period - bad…
The 606 were voiced on KS-1. It’s zero risk in my opinion. And they are very reasonably priced…
Which plug should is to take - chord ohmic?
Termination plugs for KS-1?
Yeah - the ones you put in the speaker and amp
Searching if I can buy (with return window) a KS-1 in Germany … not so easy to find…
Just buy from Cymbiosis
I have KS1 and it is very good. I have Naim plugs at the amplifier end and Z plugs at the speaker end, which seems to be a good balance. I bought mine from Signals, a U.K. dealer. But if you have NACA5 and are happy with it, there is no reason to try something else.
You shouldn’t need to change from NacA5,to be able to hear if you like the 606´s.
