Did the demo give you any insight into whether you would personally prefer the uplift from moving to a higher end passive amp as opposed to going active by doubling up on an existing amp?
Not sure where to go next, stick, ND555, speakers (start active but which power amp?), but not in a position to do anything at the moment. The demo certainly gave some pointers though.
I have the best âreal worldâ Naim pre amp in the 552, and would never move to a passive pre amp. Naim pre and power amps were designed to work in tandem and there is no sense in my mind to break the synergy with a passive pre.
Kind if where i amâŚits not such a bad place thoughđ
Ah, no, what Iâm asking is - assuming you held the Naim preamp constant - did the demo give you insight about whether you would prefer to upgrade amps by going to a higher level passive amp or by going active with the amp level youâre at?
@snarfy, sorry, got the wrong end of the stick, I see what you are asking.
This demo was not the best to answer your specific question in that passive and active demos were done with the same model power amps. I have however heard direct comparisons between 2 x 250DRs active vs 300DR passive into Titan 606, and 2 x 300DRs active vs 500DR passive into Titan 707, both systems using pre production SNAXOs at that time.
IIRC, the active 250s beat the passive 300 but the active 300s was a score draw with the passive 500, both with great but different presentations. So, not conclusive about which power amp to go for and whether to start passive with the option of going active later.
As I have an SL full loom, the sheer cost of connecting up an active system does raise concerns in my mind if I stick to SL. Anyway, I donât need to lose sleep over that conundrum quite yet.
Interesting Nigel, the 300 active vs 500 passive was where i sort of came outâŚbut eventually preferred the 500 passive , but as you mention that was pre-production snaxo at Audio show east.
The active 250,s take me back to my active SBL days with fond memories, but probably not accurate memories.
Thank you. Thatâs very interesting. Seems like you probably canât know which way to go until you try it. In my case I would be going active from a starting point of 32.5/hc/250/Allaes. Having never heard 135s or an active system I would probably have to just take the plunge if I ever stepped up from a single CB 250.
Presumably then you would be looking at a CB SNAXO and adding a CB 250, or are you thinking of moving over to classic black boxes?
30 years ago I was running 72-140 into ES14s, I went to the Sound Org London to listen to 72-HS-250, Derek suggested I also listened to a pair of second-hand 135s they had in, I left in a cab home with the 135s and a loaner Hicap.
What exactly is timbre?
I wish you hadnât told me that!
Youâll notice it if you listen carefully to the Lumberjack song! Sorry, couldnât resist.
I use the adjectives âtoneâ, âtimbreâ and âtextureâ to describe how real instruments sound. I find it difficult to articulate exactly what I mean by those terms other than their presence in a recording always makes instruments and voices sound live, the real thing, rather than a facsimile.
A passive pre is, in some respects, similar to a passive crossover insofar as the line signal itself powers the components used for signal normalisation.
While Iâd not write off a passive pre out of hand, this design approach would make me cautiously wary. Iâd want to validate such a unitâs performance with a wide range of input signals of various voltages, recording levels and frequency bands. All something an active pre doesnât worry me about (as much).
couple of photos from yesterday
first demo room NDX2/XPSDR/252/SCDR/ 2 x 250DR SNAXO into Kudos T505
really liked the T505 when active with 2 x 250 more detail, focus and music clearly showed the uplift from single AMP - but it did really come home to me when the NDX2 got its teeth into the higher res files - Diana Krall Imeda May Tori Amos Elton John Meldoy Gardot
i need to think going forward re active 2 x250 or keeping my 300DR, as I dont think the budget is there for another 300 in my system, and I love my 300 in passive
the big one, which was full all the time when I was there
Kilmax LP12/ND 555/2 x 555 PSU/552/ 3 x 300DR in active/SNAXO/T808/NAC5 cable/ standard in connects
in active mode the best musical system I have heard in my NAIM journey when through LP12, sublime musical heaven - as you should get for the best side of 180K
ND 555 for me now is the new streaming bench mark through 2 x PSU, but again 28K streamer
great even - good to meet a couple of other members @NigelB - had to leave around 2pm so missed the PM visitor
one of if not the best Demo day I have been too, thanks too @Cymbiosis and Derek & Dave from Kudos
love the T505âs
other members of the Titan family ready to demo T606 & T707
one hell of a source!
@Steve. Well i donât know. Iâve just heard it several times now with various speakers in different configurations and I donât think I would be persuaded to part with that amount of money. Also strikes me that guys on here have gone to considerable lengths to get it sounding right. But who knows how it might be in my system and my room?
Lindsay
I should add that it was great to meet some like-minded folk and one or two from the forum, @LindsayM and @Antz - nice photos BTW.
I thought I would be meeting Lindsay for the first time, but it turns out I have met him before at other demos/shows. Always difficult to match up a face with an avatar! (I removed my Fez just to confuse everyone.
Good to see you again Lindsay.
I heard the T505s in passive mode at a recent Acoustica show and was really unimpressed. They sounded flat and grainy. It might have been due to the system setup on the day but IMO theyâre very over priced at ÂŁ7K. ATC speakers are much better value.
