NAC 52 and POTs 8?
Can anyone tell me what upgrading a older 52 (POTs 4/5?) to a POTs 8 will do?
Are the POTs 8’s still available? I thought I saw a post mentioning they weren’t.
The long version:
The short version:
Tht OP might also want to go back in time…
Naim Forum Archive - 52 Updates
“Owners of 52 with pots earlier than Pots 7 (S/N 126147) could benefit from an upgrade to pots 8.”
As @robert_h posted above, Class A can now again do the POTS8 update.
Maybe combine with a Service…?
Would that also mean they’d be available in the US?
Thanks!
Don’t see any reason your US dealer/servicer can’t request the parts direct from Naim UK.
You could contact the distributor or else Chris West at AV Options and ask what your options are.
I could not say… :expressionless:
Class A are based in Sheffield (UK).
You should do you own investigation.
Check with Focal/Naim in Canada. Michel is the guy to ask for N.America availability.
Thanks! Will do!
