It was a Naim passive crossover - probably from IBLs. It was probably close enough to work although it looked most ungainly hanging of the back. Luckily the Kans were tucked away up in the corners so not so easy to see.
IIRC the very earliest NAIT2s had a fault on the PCB which meant that the speaker channels were reversed. Too late to change so the rear labels were modified. It ws eventually corrected with a revised board.
You have serviced a few of mine that were like that Darran. Makes speaker connections easierā¦.
Mine, the one that you help to sort, has the channels reversed.
Yes, Bandit. Yours has an early Nait2 serial number.
Thereās a few NAIT1 out there which have ch1 and ch2 swapped on the ātunerā DIN input.
Must admit Iād never noticed on mine until I read about it and checked!
Interesting these early production differences!
Mine (also sourced by @anon27418182) has the channels as usual, so with the revised board then, serial no. 498XX
Indeed - mine does this.
Thatās an interesting perspective. Iāve not had the C but I did have an older AT95E and when the VM line replaced, it I went straight for the AT-VM95SH. I wonder if Iāve chosen the most boring of them all.
Iāve got the VM and SH stylus. VM is the livelier one. SH sounds a bit more meaty. Most of the time I use the VM. But if a record is particularly bright sounding, the SH tends to sound better.
Great that itās so easy to swap out stylus tips to tweak the sound
The SH is the only one I donāt have so canāt comment on it. The C and E are so cheap that you might as well experiment if and when the mood takes you.
Finally found a good balance for the Lingo/Ekos/Adikt deck with the Kan 1s. The 42.5/110 seems to be the key instead of using 12/160 or 32.5/160. The slightly clearer 42.5 and punchier 110 help cut through the thicker MM sound. I love vintage Linn but itās very coloured and a bugger to get sounding right. I suspect the Nait would be even better but I need all the bass I can get. This is now more musical than with the same spec deck but with rebuilt Troika. Itās taken ages to get this far but mostly been steps forward.
Good result! The 42.5/110 is surprisingly open sounding and quite honest to the source sound so Iād say the LP12 setup youāre using is really working well or youād soon know it.
Recently Iāve once more reintroduced the (now freshly serviced) 250 in place of the 110, along with the recently serviced 42.5/HiCap and (at long last) Iām getting the kind of result Iāve been hoping for. Itās that sound where technically everything sounds just right, yet Iām not distracted by that - instead fully absorbed in the music.
My only problem now is the 250 aināt got a chrome bumper
Sorry, we canāt talk to you about that here ![]()
No, thatās good hear. The 250 is a lovely sounding amp and got bags of control.
Great place to be and one that can be very elusive. Itās no good having a wonderfully coherent and tuneful system if thereās some element of the sound that is distracting you all too often. Itās like lazy Hollywood film making when youāre suddenly taken out of the movie experience cos something is unbelievable.
Snarfed this beautiful NAXO 3-6 on eBay on Sunday night for a very reasonable Ā£225: my plans for a dual-mono pile are coming together nicely, bwah, ha, haā¦
But letās have a look around the back, shall we? What is going on here⦠and a 7-pin DIN input on the NAXO..?
I think a sleeve off shot is neededā¦
This cannot be standard, can it�
