I installed my Fraim today. Some thoughts and a question…
I have two medium levels and two of the standard levels. A Rega Planar 8 is on top. Is it too tall? I was thinking about replacing one of the medium levels with a standard level.
Sitting under the turntable is a split Nait 3R with some upgrades. NDX under the Nait. Under the NDX, a Hicap DR. Finally, a Supernait 2 on the base…perhaps to be replaced by an olive amp someday.
The Fraim is a brilliant design…especially the method to level. It makes leveling very easy. I would say it definitely is on par with a box upgrade and perhaps moreso as it’s a holistic upgrade for the entire system.
Sorry to be a bit of a wuss but if you are under doctor’s orders, is there any chance you could spare a few coins for the dealer from whom you purchased the fraim to have one of their folks pop round and help you assemble it? The fraim levels aren’t particularly heavy; it’s the boxes which can be both heavy and awkward to place on the shelves. Plus if you don’t have much clearance behind the rack, it may be a bit of a stretch to install the interconnects, etc. Don’t underestimate the load this can place on you if you are carrying an injury. Take it easy.
I have some arthritis of the facet joints in the lumber region of my back where I have mild disc degeneration. When I do a rebuild of my two Fraim stacks I can create a flare up and inflammation lasting for days if I’m not careful with everything you mention. Those power supplies are really heavy and awkward to manage without putting pressure on the back.
Thanks Peter
It’s OK - the initial ‘no heavy lifting’ ban is almost over (so long as I then don’t go mad ie going back to work for 2/3 weeks) so the SuperCap…rest…Supernait 3…rest…routine will be fine. If it takes longer, it takes as long as it takes!
Luckily, @JosquinDesPrez, my situation is just post-op, my back is OK. My sympathy to anyone with a bad back - not pleasant at all.
But if I run into set-up problems, you bet I’ll be on the phone for the dealer’s assistance!
When you have done it once, it gets much easier each and every time. Of course the levels will remain assembled as you will only have to check their three nuts and locks for tightness on a rebuild.
The real difficulty is to level the base at the beginning and more importantly the top level at the end while keeping the spike in the middle of the chips receptacles.
Positioning the glass shelves and avoiding their getting out of place also requires care and attention. The balls are quick to escape and the fear to scratch or brittle the glass falling on the wooden shelves will add 10 wrinkles if not 10 years to the counter everytime.
