Yep… Guess thats an option as well though, perhaps, less aesthetically pleasing.
Oh I say - that’s rather satisfying! …is your Radikal flush at the front?
Rather lovely…
Need to do some dusting though
Indeed
What about a very good body shop spraying it gloss Black and clear coat
That may be worth a try - it’s a one way ticket obviously! …had anybody ever done that?
Yonks ago I had my ’wood finish’ Thorens TD160 resprayed to black whilst it was being refurbished…still looking ok and going strong…(now with my son in regular use)
Rather than spray it, get it wrapped, much cheaper and if you ever change your mind, just pull it off and it will be exactly as it is now
Do you think it would easy to wrap Fraim shelves?
Wrap? In what? Scuse my ignorance…
Looks of show cars are wrapped (essentially vinyl) and they can look brilliant if done well.
A good car tint/wrap specialist could wrap any of the shelves or uprights in a Fraim etc
I have also used good car Bodyshops to repaint or colour match guitar bodies, so they could certainly work the wooden plinth on an LP12 too.
I think Window Tint might be better. You could do 5% or what’s called Limo Tint. I’m pretty sure though anything applied to the glass will change its resonant characteristics. Could be better could be worse could do nothing.
Yes and no, it would depend on how well you want the inner cutout wrapping, a good person may do that OK but it can’t really be seen either; the outside should be dead easy
Now THAT is an interesting concept… High gloss white maybe
Or you could do something like this -
But it is a bit more permanent than wrapping.
A good wrapping firm, will find it easy to wrap the fraim and most things actually these days
That is what I would rather than spray it.
I had already considered getting my fraim legs wrapped to match the fact 12 colour, but haven’t bothered to try and sort the right colour as yet
Yeah, it’s the cut outs that I was thinking could be the problem to do well.
