When I sold my house here in Balmain (Birchgrove actually) I just left the fraimlites as is in my storage lock up but I had the boxes and bits for the fraims ( have them for fraimlites but couldn’t be bothered )
Some of them went to southern highlands and we just loaded them up in Harrys van/car with a few cardboard bits between them worked a treat
My 12 Faim boxes, reduced to 11 on site were about 6’ tall. My dealer said nobody keeps these and collected tham after the install. I wouln’t reduce eveything back to how it arrived. Some old towels to separate the layers?
Shrink wrap them…… and if in an obsessive moment, then bubble wrap and store in a card board box - it’s what I do with almost anything I cherish which I wish to move.
It’s a doddle to dismantle. If you can build a house you can take a Fraim apart. Just use the Tommy bar to loosen the spikes on the levels, and the spanner to do the base. Take it completely apart, wrap the shelves and glass in blankets and put it in a box. Do similar for the legs and metal bits. It’s a piece of cake. People get terrified about setting up their own systems, it’s really odd.
Yes… for me, it’s completely the opposite. A rite of passage. And just something I deeply enjoy. The more I grunt, the happier I am because the end result is always gratifying after the tweaking and tuning over weeks, sometimes months.
My experience in moving to Fraim from various other racks is that it was a clear step forwards in the musical integrity of the system. Everything just made more sense and was more involving to listen to. I would say that the imrovement gained is more fundamental than a black box upgrade.
I put my Fraim in storage last Aug to use a Quadraspire SVT single rack instead in my alcove a with matching turntable shelf above.
To cut to the chase, the turntable shelf didn’t work out (due to uneven wall) so I reassembled the Fraim at the weekend with Naim boxes duly installed. It took sometime to adjust the base to get it perfectly level but after that it was plain sailing!
I’m still amazed at the difference in SQ! Very happy with the performance of my system now. Definitely on par with a black box upgrade
