The difference between the Atom and the Star/Nova is massive, but then again, so is the price.
Has no one mentioned the risqué flake adverts of yesteryear yet?
Well Clare…after the first song of the 3rd album (all at 70…75…80…even a song at 90…then back to 70ish…) the Nova stopped and a warning came on the screen of an overheated or hot situation…as you saw I have it sitting on a heavy wood base…
This is all very interesting, given that China (as far as I can tell) are saying that all is well at their end, there does seem to be a huge queue of people waiting for stuff right across the board not just hifi.
Me thinks the truth is not being told.
The casework is a heatsink so making sure there’s space for air to circulate is important. Also it likely runs cooler with server mode switched off. Otherwise, make sure the speaker cabling isn’t causing the amp to run hot - in particular, stay away from woven litz type cables of very low inductance or ribbon cables of very high capacitance. You need cable combining low capacitance and moderate inductance - many figure 8 types (NACA5 recommended) should be OK for this, so long as they’re long enough - see the forum FAQ on this.
Oh, come on. It’s completely free-standing, the thing shouldn’t overheat, server mode on or off.
Regarding the cabling, wasn’t it confirmed somewhere (by @Naim.Marketing?) that this does not affect the Uniti range, only older amps?
I would guess it would depend on how hard it’s being driven (and how tough the speakers are to drive), the ambient temperature, how much air is allowed to circulate, and how much internal processing is being done (hence try with server mode off).
Re. cabling, while the Unitis and NAITs are much more tolerant of speaker cabling, very low inductance or high capacitance cables should probably still be avoided, as they may well result in hot running.
AFAIK all Naim amps have a thermal trip on them to protect the electronics from excess heat (IIRC it comes in above 70 degrees C on the amps, not sure on the Unitis). Are you saying this should not be necessary?
Airedog, if it persists, I would have a chat with your dealer and get the unit checked.
@airedog - and as per the other thread, you are using AQ Type 5, which most likely has high capacitance.
Many AQ speaker cables are constructed in ways making them problematic for Naim units, such as being internally bi-wired, although Unitis are less picky. The AQ Type 5 has “Balanced Star-Quad Geometry” according to the AQ website. According to https://en.wikipedia.org/wiki/Star_quad_cable, this results in high capacitance. As AQ does not publish electrical specs, it is difficult to tell if it is suitable cable. I would try with a non-fancy one and see if the overheating goes away
Slight mod…I have placed the motion absorbing pads for under washing machines under the Nova. They are rubber or whatever so I’m watching the temp. We’ll see how this works. I can also drill holes under the Nova for circulation. Or…you know…trade it on on a SN3 and NDX2…
I really would pay heed to the comments re cables. I’ve run my Nova VERY hard - even in high temps - and it’s never once tripped the thermal cut-out. I’m using NAC A5 and it’s sitting on a humble Naim Fraim shelf (not a Fraim, just the shelf/supports)
I’m going to grab a pair. And a Powerline. It’s only dirty money.
What will the ice cream industry do ?
Yeah, not long at 70 ish volume and it’s getting pretty warm. I turned down to 40 to see if it moderates the temp.
Yep, that’s the one!
And what minimum length do I need?
We shipped 4m lengths with the recent Uniti/Focal systems we created - we tested with all combinations and found this worked really well.
That Naim takes so much care to get the best sound, even with their lower/entry systems is one of the many things that I really like about Naim.
