A friend painted this. It’s going to be framed and put above the 552 ![]()
It’s called “emerging from the rabbit hole”.
I can arrange to send you the original
I’d love a copy of that…![]()
A youth that is mis-spent is never really mis-spent
Needs the words LP12 Sondek at the bottom ![]()
Unfortunately their can only be one original. ![]()
I don’t need an original, good quality print will do me just fine😊
Copy the image and print it, it’s only black and white so it shouldn’t be issue.
Thinking now I had my painting hanging upside down.
I’m very aware of Pareidolia. Or folk making something out of random things.
The paintings orientations before had an “angry grandma” look to it.
This way seems to have some more natural flow with weight. Which should give the onlooker to think more of naturally occurring forms and shapes instead of looking for faces.
Is odd isn’t it, Pareidolia…
Because now, painting turned, I see two gnomic faces as if in close conversation, one face half hidden by the other.
Whereas before, only a very vague head shape.
That piece will work either way.
I was once told by someone who studied art that abstract art should look good at all rotations but there is a correct way round. That made it even more confusing but I thought I have four for the price of one!
Atb
Kk
This is the only sculpture we own. It’s by Carol Peace. We bought it years ago at a sculpture park in north Devon.
A touch of Giacometti, nice piece.
A new picture has gone up on the music room wall:
Expertly framed print with UV/70 glass, and with an aged gold edged and delectable burl walnut veneered frame.
Nice frame, suits it very well. Why stop at uv70? Probably because the framer can’t be bothered?
Budget, the 99 costs a lot more.
It’s hanging in a room that is fairly well shaded from sunlight anyway.
The costs of glass such as UV and non-reflective has rocketed over the last few years
Just as an example, if the glass in your picture is 2ft square AR99 would cost the framer £45.50. UV70 would cost £22, making it £23 more. Just for interest, what did he charge and quote for your job and then using AR99?
