I’ve not heard of a 3R, but the only Olive kit I’ve ever owned is the CD2 and know hardly anything about the Naits (went from CB to OC, with a long gap between).
My mate had a Nait 3 before moving on to 102/HC/180. Really enjoyed listening to that Nait, a gutsy little amp, not the last word in refinement but full of groove.
It looks like it’s had the Nait3 split kit fitted. Originally the pre and power sections would have been linked internally, but IIRC, there was a dealer fit kit available to add the extra DIN4 socket to the power amp board. It’s now linked externally by the Flexi link plug
Yes, that’s the power amp in socket. This would allow flexibility like the later integrated amps. You could use it with a Flatcap connected via a SNAIC5 to the middle DIN5 and then return the signal to the power amp in socket (left) via a SNAIC4.
The Nait 3 was my first Naim amp. Partnered with a CD3.5 and FC it was a pretty special setup. Congratulations. What components with they be using with the Nait3? None of the Naits I’ve heard since have the magic the little Nait 3 has.
She already has a pre-loved Rega Planar 3 (with a Goldring MM) and an ex-dem Naim CD5si. Speakers are Wharfedale Diamonds. Amp is a Rega Brio, at present.
A nice little system - which hopefully, will become a little nicer still…
Will be interested to hear your thoughts on the Nait3 vs the Brio. I have a Brio that my daughter was using with a P1 and my IBLs. Didn’t sound great to be honest as the IBLs really need much better up front. The Nait3 might work better with them being from the same era.
My partner had a ‘music centre’ style unit, but with Wharfedale Diamond speakers. This was upgraded with a pre-loved Rega Planar 3 and an ex-dem Naim CD5si (both sourced from a well know Leicester shire dealer…).
Checked both the rear panel fuse and the mains plug fuse - both were OK.
There were no lights on on the front panel. Tried signals into several inputs - nothing.
This Nait 3R has been 'split - so its sections can be used separately, if the Link plugs are all removed. So… I did that - and fed a HiCap into its 5 pin 270 degree. Bingo. Lights on, responded to switches.
Have just now ‘inserted’ it into my system with HiCap and 250 - and its working. Yay…!
My guess is that there is something amiss with the Power Amp/PS section, which has killed the supply to the Pre Amp section. Powering the Pre section results in full function.
So… I think it needs to go north, to see @Darran at Class A, as soon as possible.
