Nait 50 Very Slight Buzz
That’s a shame. There might be another test you can do, but I’m afraid I’m out of suggestions. It seems like you have two options: live with it or get it back to Naim for checking. Maybe your dealer would lend you something while it’s away. What a drag.
Sorry yes it’s a buzz not a hiss. My mistake - now corrected.
That’s ok. Sounds like an amp issue like you said. Does the transformer buzz?
Only very slightly sometimes but not an issue at all, unlike some of the older stuff.
Very sorry to hear that Pete.
Best get it sorted out or will drive you nuts wondering what’s up.
It seems others have had a similar thing but no explanation of the outcome.
Here is an AI answer I got from a JBL Google search.
I did speak to Naim support and guy I spoke to thought that it was slightly worrying that it only seemed to be present on one channel. However he felt that since it is very low level, and really only audible at around 10-15cm directly level from the front of the speaker, and then very faint, that it probably wasn’t anything to be concerned about. He suggested I get it checked over if I was worried but otherwise just keep an eye on it and take action if it gets any worse.
So I’m in two minds. Returning it to the dealer, located around 20 miles away, will mean using Parcelforce or similar. Then waiting for it to be sent to Naim, get checked, and then sent back to the dealer. Then arranging to get it from the dealer to us. Could take up to a month apparently. So much hassle and expense. I just have a feeling that it will come back the same!
Can you not take it to your dealer? The bigger question is this: can you live with it and put worries out of you head? At least if it comes back the same, you’ll know it’s ok.
Thanks Skeptical. You’re right it is going to drive me nuts but having spoken to Naim support they seem to feel it probably isn’t anything to be concerned about. They suggest keeping an eye on it to see if it gets worse as it is such low level only. It’s going to be a right pain to get it sent back though. Think Ill just leave it for the moment. If I can’t put it out of my mind then I’ll just have to get it done though. But will take around a month probably!
If it was worrying to him then sucking and see won’t do anything.
I’d have to find the answer.
Reading the Search I did above would suggest an oversensitive speaker unless I’m getting confused.
At this kind of emotion and expense I’d have no problem visiting the dealer he might have one to swap. :thinking:
Yes I think I’ll speak to the dealer. It’s 20 miles away though. No car here. We used a taxi to fetch it and cost £50! It’s more or less in the sticks so not easy for us to get to. I know he does have a demo N50 there so maybe he can come up with something.
It will cost £50 to get a taxi there / back. TBH I don’t know if I can live with it - it bugs me even though it doesn’t actually affect anything. I’ll speak to my dealer.
It’s a pity you cant try another set of speakers because if you have swapped the right and left over at the amplifier and the noise is the same speaker it points to the speakers not the amp. :thinking:
Sorry Skeptical I mislead you there. I actually physically swapped over the speakers. Would have been easier the other way, at the back of the amp, no?! My bad. So swapped the speakers round and the buzz was still on the LH channel.
Not sure if you still have the old amp?… that would fill in for a while? .. but don’t worry if you can’t play music for a few days - it’ll free up some time for the occasional forum post.
I don’t. Could take a month to get the N50 back, and no guarantee it’ll be any different. I just have a (completely unfounded) feeling that it will be exactly the same!
Hi Pete
Just to lose confusion leave speakers where they are and find the noise then swap the cables over and see if it moves if it doesn’t it’s a speaker issue.
Best be sure before you organise a travel. :thinking:
Thanks Skeptical, yes I’ll do that.
That’s too bad. (Never hurts to keep a reserve squad on the payroll just in case :wink:)
I’d suggest you ask the dealer, who will send the amp back to Naim using their courier contract, to schedule the pickup from your house rather than from their place. It can then go direct from your house to Salisbury.
Where abouts in the country are you Pete?
