Nait 50 Very Slight Buzz
We’re in the Midlands.
Thanks that’s really helpful. I’ll see what my dealer says.
Cheers Pete, unfortunately not local for me, was just going to offer some swap in gear if you needed it if we were by chance in a similar area. Hopefully if needed your dealer can organise something if you need to send the Nait off.
Thanks Adam, that’s a very kind thought - much appreciated.
Well at least its not a car and you do not have to put up with ‘they all do that Sir’ Good luck. Trying to ignore a quiet hum which I thought would go when elderly Rega 3 was retired.
more than welcome Pete.
OK, just spoken to my dealer and the situation is this. He has never heard of anything like what I’m experiencing with the N50. They can arrange for it to be picked up from our house but it has to go back to them first, it can’t go directly to Naim. This will obviously incur a charge regardless of anything else. Additionally if Naim don’t find anything wrong with it then it will incur an inspection fee of around £85! So if no fault found then we will probably pay around £130 or so total.
I think I’ll just leave it alone unless it gets worse.
Hi Pete
Did you try the speaker cables swapped it might not be the amp but one speaker different in sensitivity than the other.
Swapping the speakers on the stands won’t make any difference as the source of power is the same. :thinking:
I had a thought: you’re using a power line, yes? Try using the Stock power cord that came in the box.
Thanks Skeptical. I’ll try that now.
It’s a hell of a life!!! :frowning:
Thanks @opus. I know the Powerlines to be fine as they are the same ones as used in my previous system and there was complete silence through the speakers. And they were 99db sensitivity!
Chin up it’ll get sorted. :+1:
Why worry about something you can only hear when you have your ear glued to the drivers? You have a warranty. If (!) anything gets worse you can act upon it and you have plenty of time to do so. Meanwhile enjoy what the 50 CAN DO … which is making music.
Hi Skeptical. I’ve tried swapping over the speaker leads at the amp. The same buzzing then appears at the RH speaker instead of the LH one. So not the speakers it seems.
I think I’ve now done all I can. So it’s either just forget it or send back to Naim for checking. As @anon24341058 points out I have the warranty so plenty of time to get it sorted if it does get worse or if anything else develops. I’ve always got that option. So considering all the hassle and expense I think I’m just going to leave it at least for now. It’s not an ideal outcome. In the old days when I had a proper local dealer I would just have dropped it in to him and it would have been sorted. My fault I suppose for buying from a dealer not local to us - but it was the only way to get a brand new Nait 50. Anyway it doesn’t actually affect music playback but it’s a niggle and a loose end that I’ll live with at least for the moment. If it does get psychologically too much then I’ll send it back though.
We’ve just shelled out a small fortune on tickets and hotel booking to see Maisie Peters at the O2 Arena in London next May so don’t really want any additional expense right now unless strictly necessary.
@70sPete
Hi
Glad you’ve got a result of sorts it might even sort itself out with longer time playing and keeping an ear on it.
It doesn’t affect the overall joy so keep on listening.
You’ve managed to track it down to something with that channel so just make sure all the contacts are clean and tight.
Best regards :+1:
Thanks Skeptical. Enjoy your system too, and your lovely new speaker cables. All the best.
I had the same phenomenon in my previous home, with the NC 250. On one speaker only. Same, can hear it only at 10 cm or less. I bought an Ifi DC blocquer, put it on the 250, before the power cord. It solved this a little annoying problem.
Interesting. I had thought that as it was only one channel (mainly) that rules out anything mains related, as I would have expected it to affect both channels equally. The buzzing does sound like a mains interference thing though as opposed to the typical hum of a ground loop. But I’ve tried switching off everything on the ring and it makes no difference.
Well Pete you might never be happy with the N50.. When you get a chance google the Naim N50 Images the interior picture is interesting looks as if the AC inlet runs right past the left speaker output. Even though the AC inlet looks well shielded. It may just be your JBL’s are very sensitive and efficient. I know what you’re thinking Pete, that might be the right move. FWIW I’m similar if I buy something and it annoys me I usually moveon, if I can afford it, sometimes even if I can’t
Also I was looking at the rear of the unit. Maybe grounding the unit might help ? What about trying instant on/ off? If your not listening turn the unit off but use instant on
