NDX2 vs NSC222
Thankyou Steve….but does this solve the problem?
Thank you for your views and input, it is appreciated.
I will, hopefully be making a comparison next week, or the week after at my local dealer. Probably with the extra power supplies, in case my financial situation improves again.
My next purchase will be an AT95 for my Pink Triangle, with an upgraded stylus :wink:
Yes, it does.
We had too many mute relay failures with infant mortality for comfort. The mute relays were called ‘change-over’ reed relays. i.e. they either connect the output to the signal or change over to ‘ground’ (mute) depending if it was playing or muting.
All new classic use a new muting method, we do not use the change over relays. We use our input selection relays for the signal carrying part of the mute circuit. These have a life of circa 100,000,000 operations.
Thanks Steve, appreciated👍
Since two weeks I have the nsc222, npx300 and the new nap250. replacement for the ndx2, xpsDR and Nap300DR. The sound is formidable. It sounds like… I’ve never heard it like that before. The music never goes wrong and it takes some getting used to. If there are people who can’t get used to the naim sound. Too bad, this is 50% more naim in the good sense. The speakers are b&w 803D4. I’ll let you know more when it’s played.
we connected the ndx2 to the full nsc222/npx300/newnap250. the streamer/dac of the nsc222 sounded much better.
What preamp did you use with the NDX2/300DR?
That is positive news!
A couple of follow-up questions:
Did you listen to NPX300 PS connected to the NDX 2 and the preamp section of the NSC222? Did you have the chance to do a side by side comparison to your NAIM classic system?
Thanks…
No, the npx300 was connected to the nsc222. The npx300 can be used on the ndx-2, but the adapter cable is not yet available.
The preamp I used between the ndx2/nap300dr was a stereoknight. A passive preamp with silver-wound transformers.
Using a passive preamp with a Naim power amp is not likely to give it the best chance of performing well. It has certainly given disappointing sound when I’ve tried it, so this could be why this system sounded below par for you.
Thanks for the response. I believe, as @ChrisSU had mentioned, the uplift in sound may have been due to the preamp you were previously using vs the streamer section.
I did not have the opportunity to hear a side by side comparison at my dealer since they will not have cables available here in the US currently. I would be interested in hearing the NDX 2 using the NPX 300 power supply within a classic system.
It is great that you are enjoying the current configuration vs your previous system.
Meaningless comparison then. Racks of Naim kit but no preamp available?
Comes down to system synergy fundamentally, all these “A is better than B” tests are subjective at best, not least the fact there’s only a handful of truly run in 200 Series systems out there (the ones used by Naim staff during development that is)
The NDX2 is no slouch as a digital source and with well matched components performs admirably in many system configurations.
The more interesting aspect is the overlap between Old and New Series from a system evolution perspective, in particular the power supply options and to an extent the new NAP 250.
I expect once the new 2/300 Series preamps materialise we’ll be in a better place to make meaningful comparisons between systems, the NSC 222 is optimal with an NPX 300 and 200 Series NAP 250, the general concensus being the new 200 Series is fast and lively in presentation, tuned more to a younger market perhaps, or keeping up with trends in the wider market, not better or worse but certainly different to what many of our ears are accustomed to with Old Classic systems.
Pretty fair way of putting the new kit vs old.
congrats for your new purchase.
I understand the appeal for only 3 boxes, but you have lost a lot of money selling your ndx2/xpsdr/nap 300 dr . You could have a Nac 252 instead , which , with your ex Ndx2/xps dr and Nap 300 dr , would for a system at a higher level than the new NSC trio.
However it would be 6 boxes instead of 3.
I suggest to hear the new classic combo. What @ariescholten is finding is the same I’ve heard myself. The NC series is something special.
I don’t think the NC series is perhaps tuned more to a younger market, nor to keep up with trends in the wider market. Naim has done a truly spectacular work around this new series. I don’t want to add any further speculation about the set I’m testing these days. I suggest you try it out directly.
I have already, on more than one occasion and in different demo systems/setups/locations.
I’m a fan of the New Classic 200 Series and I’m sure it will sell well (to those who can afford it or are willing to finance it).
My comments are merely observations and not to be read as statements of fact or absolutes. Individuals will make their own choices with their heads and wallets ultimately!
I’m more than satisfied where I am today, even if I was desperate to upgrade I can’t afford to anyway so my decision is an easy one :grin:
Now it’s clear to me. Sorry, I misunderstood your statement. I’m also very happy with my (old) classic series.
